HS 1.8 Dyno Results
Old Apr 25, 2004 | 10:54 AM
WAHUSKER's Avatar
Default HS 1.8 Dyno Results
A month ago after installing the LSX, I got 355 RWHP SAE on a DynoJet. Yesterday I layed down 370.6 RWHP SAE. This was after installing the Harland Sharp 1.8 Rocker Arms (+ LS6 valve springs so I could rev past 5500 rpm). I also gained 2 lbs of torque, now at 360.7 RWTQ. This is on a stock motor, with an A4, 3.23 gears & 315 tires. And I can now rev to 6300 rpm before the hp flattens out!
I will post the dyno sheet on my website in the LSX & HS album.
Old Apr 25, 2004 | 11:00 AM
Racehead's Avatar
Not too shabby for a bolt on A4 car. Just think, with an ORP in place you'd probably be at the 380 mark ..... Mark
Old Apr 25, 2004 | 11:05 AM
WAHUSKER's Avatar
LOL...too bad I'm a tree hugger. Swap out my A4 for a 6speed, and I might hit 400!
Old Apr 25, 2004 | 01:53 PM
lsx24's Avatar
I've never seen the stock cam that stable near 6k. That's amazing for a bolt-on A4! What year is the car? Even before the rocker numbers are real stout.
Old Apr 25, 2004 | 06:49 PM
Nasty N8's Avatar
Thats a pretty good gain.
Nate
Old Apr 25, 2004 | 06:53 PM
Racehead's Avatar
Yeah but then you'd have to learn how to shift j/k lol !
Old Apr 25, 2004 | 07:04 PM
WAHUSKER's Avatar
Nate
I thought you'd like that Nate. I was pleased! The strangest part about these rockers & maybe explains why I gained so much is my car was always lean....to the point of KR. I got a couple custom tunes form RWTD, and they helped. His last one finally got the car close. But the rocker arms made the car a LOT richer. Not sure why, but my A/F was 13.1 at 4000 rpms & 12.8 at 6200 on the dyno. Never has it been that good!
Oh, and my car is a 2000 Ram Air.
And you better be nice Bill or I'll tell people you painted my LSX.
Old Apr 25, 2004 | 10:51 PM
nuzee's Avatar
Was the power gains seen only up top (>4000 rpm) or did you see an across the board improvement?
Old Apr 26, 2004 | 08:25 AM
WAHUSKER's Avatar
Dang, I forgot to figure that part out. I got so wrapped up in trying to figure out where I wanted my tranny to shift that I didn't look at that. Visualizing the chart I wanna say it was across the board, but I will check when I go home & tell you for sure.
Old Apr 26, 2004 | 07:38 PM
WAHUSKER's Avatar
The gains all came above 4k. After the PPC headers & before the LSX my car climbed steadily to 345 @ 5900. They helped across the board. With the LSX it continued to climb up to 355 @ 5500 & then flattened out. It also helped above 4k. Now to climbs to 370 @ 6k & flattens out.
Old Apr 26, 2004 | 07:48 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Nice gains for a rocker swap. Congrats.
