New #'s 403ci N/A 559/508
Yes nitrous will be added this year prob around 100-150
Bacon: for the weight I can really only do the front k member/a-arms but other than that there's really nothing else adding the n20 is cheaper too lol. Going to get a real weight check soon I think that scale was off at the track have to take a ride to a scrap yard for an accurate weight.
Looks good thanks for the pics. I'm wondering how I'd get the vacuum source now since I have Holley valve covers and I don't have that oil fill cap screw in thing anymore but rather a threaded oil cap that screws in. Might just have to drill and tap the oil cap I have now. I like what you did with the adjusting valve as well.
Also, for the 5ft line supplied, I assume you didn't use all of it, but do you think 3ft would be enough for how you routed it?
You should seal that dipstick off as well I've read you can still draw in air from there. Some people have taken an old spark plug wire and took the boot off and put it over the dipstick tube and up to the yellow handle so it seals and you can keep the dipstick installed in the tube still.
Might get away with 3ft n yes I had some left over its just easier to buy the lsx kit from Gz all pieces needed..... for your valve covers I'd just drill a hole n thread a -10 fitting in it my case I found this fitting on eBay from hawks third gen. Good idea on the dip stick thing I'll have to do that.
I agree with Jesse. Nice Results!! That vacuum pump with that kind of horsepower gain should definetly drop some e.t at the track and by the way that scale number do seem a bit off cause that's on the heavy side. I know you mention the k member don't forget about a front bumper support from mwc. That's another 20lbs off the nose for only a coll 150 bucks ;-)
#40
That I'd have to research on what a certain lb clutch takes to spin/t56/dana60 with 410s if I were guessing 620-630 figuring a 60-70hp to spin everything. W.e. that is in percentage
