Brian Tooley cam, stock LS1 241s, FAST 90/90, TH400, 9" - 420 RWHP
#41
01 ram-air, do you remember the piston to valve clearance you had? Your 241 heads are stock, non milled, correct. Trying to see if a cam this size would clear my setup. Current cam is 227/235 110 LSA and I've currently got .069" intake clearance and .101" exhaust clearance.
#44
What length pushrods did you go and any reason you went with the Comp Cam trunnion upgrade vs Brian's trunnion upgrade? I am looking to do a very similar setup with the BTR Stage 4 and stock 241s on my '02.
