Polluter V.2 Cam Only 462/427(69rwhp/37rwtq gain over stock)
2005 LS2 C6 Corvette
-Stock heads
-Stock LS2 intake and TB
-BBK cold air intake
-Kooks 1x7/8" headers
-Kooks 3" ORX
-Billy Boat exhaust
-Tick Performance Polluter V.2 camshaft 239/244 .624/.595 111lsa
-BTR Platinum springs .660" lift
-Comp Cams .105" wall 5/16" diameter 7.400" push rods
-T56 transmission
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/PolluterV2vsstock_zpsa7ada105.jpg)
On a LS2 with 11:1 compression the V.2 is a monster. The SNS Stage 3 wouldn't of lost the torque the V.2 did under 3500rpm. The later IVC and added overlap the V.2 on a 111lsa has vs. SNS 3 really makes insane power from 4000rpm and up.
The torque curve from a 239/244 cam is awesome. 400rwtq@3650rpm is impressive. This Vette is gonna fly!
-Stock heads
-Kooks 3" ORX
-Billy Boat exhaust
-T56 transmission
This cam in a light weight mustang with a lq9, ls2 or a high compression ls1 would fly. I could easily see a 3000# notch going 9.90's all motor with a 5200 rpm stall.
Super Hulk Smash
What about the TFS 205s... they are 58cc chambers with better than stock PtV clearance. They flow 300cfm, so better than 243s but actually have a smaller port on them of 205cc...
I would think the Polluter v2 and TFS 205s could be a bolt on 480+rwhp combo for an LS1 with insane throttle response.
With your compression, either cam would be a large increase in power over the SNS 2.
Nice!! having that kind of torque curve is what i'm after more than max hp really bc the car is a 3850 lb gen 1 cts-v... might get the car back today or tom... i'll post the graph when i get it
thanks again Martin
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I agree. The 48 IVC@.050" would work very well with that CSA and valve area the 205's have.
You would need to fly-cut knowing what your P to V was with the SNS 2. The SNS 3 affords around .010-.014 better clearance on average than the Polluter from what we've seen.
