491RWHP 448RWTQ Cam only LS3 2014 Camaro SS 1LE
2014 Camaro SS 1LE 4,000 Miles, Stock 3.91 gear, stock wheels and tires.
Maryland Speed 1 3/4-1-7/8th Stepped Kooks headers, Factory exhaust no cats.
Cold air Inductions CAI
NPP fuse pull (Keeps mufflers open under all conditions)
LS3 Polluter Cam kit from Honey Badger, AKA Martin Smallwood
Tuned By HotShot Performance Tuning on a DynoJet
12.0-12.3 AFR, 25-26* Timing
Thing is a roll monster for the 3 mods it has
You right they don't mess around. I would had went with this cam but I was so worried about ptv issues cause I got ls3 pistons in a 6.0 block and I heard the piston sticks further out the hole than the ls3 block so I ordered the 229/244 cam from btr which is very similar to the cam Martin has
The ls3 polluter cam is by far the most repeatable "large" ls3 I cam I've ever ground. It was slated to be released as a new stage three torquemax cam, but I felt it belonged as our flagship ls3 cam.
I tested this cam for almost a year with various shops across the country.
It has never made lower than 484/441 cam only. I'll post up some more cam only graphs I have for this cam here in a few hours.
This car will be will over 500/460 cam only with aftermarket exhaust.
The stage two 229/244 112+4 will pull 475-490/440-450 all day.
We have a great line of ls3 cams for sure. Lot of hard work to get there.
