Tick SNS Stage 3 cam results UPDATE! Track results!
Old 06-11-2014, 09:33 PM
poltergeist 02's Avatar
Default Tick SNS Stage 3 cam results 2015 UPDATE! Track results! Martin, you will like this!
I just got the call from Speed Inc. earlier today and thought I would share. The parts that helped make this happen are
Morel 5206 lifters
Manton 11/32 pushrods
Stock port 799 heads milled with the bowls hogged out by me (11.3:1)
BTR TI spring set
Fast 92mm with 90mm tb
ARH 1 3/4 stepped to 1 7/8 headers
ARH 3" Y pipe with viberant 4" merge, viberant muffler dumped
454 RWHP/419RWTQ
I will post the graph as soon as I pick up the car. Track times to follow.
Old 06-11-2014, 10:00 PM
97camaro383's Avatar
Nice results! How high did you pull it to?
Old 06-11-2014, 10:05 PM
Thanks! I'm just happy that the car gained 50hp and almost 30tq over my last setup. I'm really not sure what rpm they took it up to, I didn't ask them when I had them on the phone. I will get more details when I pick the car up.
Old 06-11-2014, 10:34 PM
I think mine peaked around 6900 and carried power to a little over 7100 and then started to drop off.
Old 06-11-2014, 10:47 PM
NW Iowa WS6's Avatar
Nice numbers!
Old 06-11-2014, 11:01 PM
1989GTA's Avatar
Very good numbers. Do you know if they locked up the converter?
Old 06-11-2014, 11:57 PM
Blackpanther99's Avatar
Great results man.
Old 06-12-2014, 04:20 AM
slowsol95's Avatar
Awesome numbers! I can't wait to get this cam in my build. Definitely post up a graph when you get one.
Old 06-12-2014, 04:30 AM
HCI2000SS's Avatar
Nice! What was the old setup?
Old 06-12-2014, 08:12 AM
Rise of the Phoenix's Avatar
Damn good numbers right there. I'm curious how much your port work on the heads helped? I would think a set of aftermarket, or CNC's 243/799 heads, would have put you right around 470. Looking forward to seeing the dyno graph.
Old 06-12-2014, 06:11 PM
I'm pretty sure the converter was locked for that pull.
Old 06-12-2014, 06:19 PM
The old setup was
228/230 comp cam on a 112lsa
Comp 5/16 pr's
Pac 1518 beehive springs with TI retainers
LS6 intake with ported stock tb
same heads (not milled though)
Stock balancer
Pacesetter headers
over the axle 3" true duals with an x pipe
This setup made 403/391
Same dyno and similar humid air
Old 06-12-2014, 07:24 PM
o2k
o2k's Avatar
nice numbers!
Old 06-13-2014, 09:20 AM
mikeygotloud's Avatar
Nice I can't wait to get my trans am up and running with this cam in it.
Old 06-13-2014, 01:24 PM
Sales@Tick's Avatar
One awesome, well planned and well executed combination with great parts.
There is no one single part here that allowed this combination to shine.
Most would say going from true 3" duals with an x-pipe to a y-pipe would be foolish. When you have headers that can scavenge as well as the ARH(I love the stepped 1x3/4" to 1x7/8" on a deal like this), along with a quality y merge you get results like this.
Not only that, the stiff larger diameter push rods and quality lifters actually allow the camshaft to operate around its designed parameters.
The bowl work and Fast intake really round out the combo for sure.
That 4500 stall and this combo is going to kick *** at the track!
Old 06-13-2014, 03:22 PM
ds98formula's Avatar
Sweet gains
Old 06-13-2014, 04:38 PM
Kingc8r's Avatar
Solid numbers I look forward to seeing your track times. Car should roll out for sure.
Old 06-13-2014, 06:39 PM
The biggest deciding factor for me was the weight savings going from full 3" duals to the 4" y pipe setup. Also, if you think about the design of an x vs a y they are very similar in the way they scavenge, but you are correct that it is Important to buy a good y pipe if you are going to use one. I'm hoping to have it to the track in the next few weeks as long as the weather is decent.
Old 06-14-2014, 07:51 PM
The Scammer Hammer
dr_whigham's Avatar
Solid. And through an auto at that.
Old 06-14-2014, 08:34 PM
Sales@Tick's Avatar
Can't wait to see the track times on this one. Should be a stout combo.
Quick Reply: Tick SNS Stage 3 cam results UPDATE! Track results!
