Iron ls2 with 216/220 .560/.560 and AI 232 799 heads. Predictions?
Old 07-11-2015, 05:26 PM
  #41
anthony soprano's Avatar
Originally Posted by drew408
I got $500 that says that's a factory oversized ls2 piston not going in a 4" bore ly6 block.
Fixed that for you.
4.0007" bore with a 4" piston would cause a ******* **** ton on piston slap and only the way a hack would put an engine together or a poor man.
So why does anyone sell a 4" LS piston genius? WTF do you think they're going in?
Old 07-11-2015, 05:28 PM
  #42
drew408's Avatar
Lol,ok Mr "I read it on the internet so it must be true"
Get some life experience and we'll talk.
A well know and respected vendor has verified this is a factory piston.
Old 07-11-2015, 05:32 PM
  #43
Also,just FYI,before the battery on my micrometer died I measured the piston at 4.005" and a vendor here (Hinson Supercars) took out of a stock low mile GTO that had a stroker built.
Original owner car bought brand new....
You're using a caliper not a mic. Please go away Mr. "real life experience."
Old 07-11-2015, 05:36 PM
  #44
drew408's Avatar
Dial caliper,micrometer,to those here who wouldn't know round from square what's the difference?
Old 07-11-2015, 05:37 PM
  #45
drew408's Avatar
And actually,it's a micrometer/caliper.....
Caliper on the backside and micrometer on the front.....but u knew that right?
Old 07-11-2015, 05:39 PM
  #46
So with all of your real life experience no one ever explained the difference between a mic and a caliper to you?
Old 07-11-2015, 06:04 PM
  #47
It's going into a virgin LS2 block. I hope I don't get any of that there piston slap.
Old 07-11-2015, 08:06 PM
  #48
Jimbo1367's Avatar
LS1Tech 10 Year
OMG.
this thread went to hell. Why would you waste the time and effort to take a pic and post it. You both have little dicks. Get over it.
Old 07-11-2015, 08:23 PM
  #49
redtan's Avatar
Lol and now we know why. This kid posts some stupid **** that he knows will turn into a pissing match just so that he can earn the required 50 posts and be able to make a for sale thread.
Coincidence that he posts a huge FS thread shortly after getting to 50 posts using a stupid argumentative thread? I think not.
Old 07-11-2015, 09:20 PM
  #50
OMG.
Jimbob, I didn't have to develop any film in a darkroom. They have these new fangled digital cameras and such. You can take pictures and post them within a couple of minutes. Crazy, I know.
Old 07-11-2015, 11:31 PM
  #51
NemeSS's Avatar
LS1Tech 10 Year
Yea,I can understand that too.
What gets me is when people say 4" bore ls2 Pistons.....a 4" bore flat top ls piston is out of a lq9.
It's surprising the amount of people who think a ls2 is a 4" bore.....
There's a minute difference in the piston rings from a ls2 to a lq9.
Ls2 means the aluminum 6.0 block itself.
Just like there is no such thing as an iron ls1.
It's a bored 4.8/5.3 to 5.7. Still not an "ls1"
Old 07-13-2015, 12:38 PM
  #52
Rise of the Phoenix's Avatar
It's going to make less than you want it to, that's my prediction.
Old 07-14-2015, 10:19 AM
  #53
ranmas2004's Avatar
This post went to crap fast......smh. See if I can bring it back.
YOUR SETUP: (MY SETUP)
Gen 4 LY6 block (LQ9 block bored and honed .020")
10.9 ls2 Pistons (new OEM .020" pistons)
ls2 rods w/ ARP rod bolts (SAME)
216/220 .560/.560 114 LSA Trick Flow cam (229/234 .600/.600 114+2 LSA Custom cam)
AI 232 heads with Comp 921 dual springs and ARP head studs (AI 232 243s 11.5CR dual springs titanium retainers ARP head studs)
All GM gaskets (SAME)
Ls9 head gaskets (OEM Gaskets)
Powerbond UD pulley with ARP bolt (25% UDP)
Kooks headers with ORY and 4" dump (Kooks 1 7/8" headers)
3" Corsa exhaust w/ dual tips (Dual 3" highflow cat exhaust with xpipe)
Ported TBSS intake manifold (Mamo ported FAST 102 intake manifold)
65# injectors (42# injectors)
90mm ported ls2 TB (FAST 92mm TB)
Melling 10295 oil pump (OEM)
Cloyes Hex a Just timing chain(single row) w/ timing chain brace (Dual timing chain)
I also have a one piece alum driveshaft, stock rockers with truniun upgrade, hardened pushrods, 22lb aluminum flywheel, custom dual 3" intake system and return style fuel system
My car put down 464whp & 427ft-lbs (SAE) on a dynojet
Its an LS swapped Nissan 300zx
Hope this gives you an idea.
Old 07-14-2015, 10:47 AM
  #54
KCS
Moderator
KCS's Avatar
LS1Tech 10 Year
You need to chill out. There's nothing wrong with arguing and debating, but childish name calling is a no go here.
A caliper and micrometer are two different things. Micrometers are typically more precise and more repeatable.
Old 08-03-2015, 08:45 AM
  #55
gagliano7's Avatar
LS1Tech 10 Year
http://www.calspeedperformance.com/p...tons%20ls2.htm
Old 08-03-2015, 11:48 AM
  #56
Jimbo1367's Avatar
LS1Tech 10 Year
LMAOOooooooo
Will someone PLEASE delete this thread to stop the bickering.
Old 08-09-2015, 09:45 PM
  #57
Russ K's Avatar
LS1Tech 10 Year
The 6L truck bore specs are 4.0007- 4.0014 and the LS2 is 4.0007-4.0017. And I do believe high limit size pistons are available from GM.
Russ Kemp
Old 08-12-2015, 08:16 PM
  #58
Camaro99SS's Avatar
Uhh, subscribing to the OP...
I think you'll be lucky to get much past 400rwhp because of the auto and the AWD. Interesting combo though. Is the cam on Phil's "high mileage" lobes?
Jason
Old 08-13-2015, 08:11 AM
  #59
Jimbo1367's Avatar
LS1Tech 10 Year
Will someone please have the MONITOR delete this thread
Old 08-14-2015, 06:38 AM
  #60
Did you know the contents of a thread only become visible when they're clicked on? I pass over threads that I'm not interested in reading and the contents don't display. It sounds crazy but it's true.
Quick Reply: Iron ls2 with 216/220 .560/.560 and AI 232 799 heads. Predictions?
