H/c/i + spray
Stock bottom end
Patriot stage 2 243 heads
Speed Inc SI5 cam 231/237 .589/.595 112
Fast 78/Fast 78 Throttle body
Ebay headers & y pipe, magnaflow catback with 3" cutout open
Dynotune nitrous kit with Nitrous outlet 78mm plate - jetted @ 150
Mcleod RXT
Faceplated, viperized t56
MWC 9" w/4.56 gears
Dyno'd with pump gas, B8EFS plugs, 18psi in the drag radials.
Window switch was set @ 5350-6900, lost traction on the hit and fought the whole pull.
Just for reference - car runs 11.3@121 N/A and has trapped well over 130mph on the bottle. Haven't made a clean pass on the bottle with the RXT and faceplated trans. I fought traction issues last season and it turned out to be a blown shock.
edit , can you post some pics of your line lock , and what brand is it .
I'm going to try 100 and see where it lands me - should keep it in the 130mph range and keep it under 7200.
