404” puts down 529/ 476 NA and 606 / 541 on 100 shot
Motor was built, installed and tuned all by RPM Motorsports in Garner, NC. I must say that these guys know what they are doing and are extremely professional in everything they do, quality work and a great group of guys to work with. Car is a 2001 T/A with a FLT level 4 4L60E with a full manual valve body and a Yank PT 4000, 4.10s out back.
404 ci 12.1:1 Compression
6.0 Block 4.010
LS7 rotating assembly
Diamond flat top pistons
TEA TFS 235’s w/ nitrous exhaust ports
FAST 102/102
FAST 36lb
RPM spec’d custom camshaft (239/251 .623/.623 @ 114)
Kooks 2”x3” headers
Kooks true duals
Nitrous Outlet 102 plate kit (100 shot for now)
N/A pulls
Nitrous pull
Only made one pull on the 100 shot, i was told that the hump in the middle of the graph is from the dyno not reading correctly during the run
6.0 Block 4.010
FAST 102/102
FAST 36lb
Kooks 2”x3” headers
Kooks true duals
N/A pulls
Nitrous pull
Nice numbers. When you say LS7 rotating assembly, are you just referring to the rods? Or did you use the LS7 crank as well? If so was it tough to balance? Many wind up trashing it in builds b/c it's a bear to balance with aftermarket Pistons and stock TI rods.
I initially took the car to RPM because i was at a stand still with tuning and couldn't figure out why my car was running like crap after returning from a deployment. Shortly after they dug into the car we found out i had a lifter going out and my passenger side head (Patriot 6.0L heads) had begun to literally fall apart. A piece of aluminum from around the valve stem had cracked off and fallen into the #8 cylinder, which did some damage to the head and valve seat.
Nick V. it cost enough that my wife wants to put a for sale sticker on the car and i have to park it in the storage unit right now.
