408 results what ya think?
Old Nov 1, 2015 | 01:52 PM
wells01's Avatar
Default 408 results what ya think?
408 11.7cr
Cam- 243/247 632/616 112+2
Heads- Frankenstien TFS 244cc In. 2.08 Ex.1.60
Ported Fast 92 intake with NW 92 TB
T56, 9" 4.11, 28/11.50 MT ET Street R
Dynoed on a dyno jet
Old Nov 1, 2015 | 05:58 PM
AINT SKEERED's Avatar
Looks like a stout combo. Not a big cam either, should drive great.
Old Nov 1, 2015 | 06:33 PM
HCI2000SS's Avatar
Number seems a bit low for that setup, but it doesn't matter...what it does at the track is what matters. I bet it rips!
Old Nov 1, 2015 | 07:19 PM
wells01's Avatar
The tires I have are bias ply I've been told the will kill the numbers
Old Nov 1, 2015 | 08:57 PM
Don't race a dyno. The car will roll out and should still have good street manners
Old Nov 2, 2015 | 06:14 AM
wells01's Avatar
Thanks guys
Old Nov 2, 2015 | 10:44 AM
Tuskyz28's Avatar
What's the numbers? They mighty small on that graph
Old Nov 2, 2015 | 12:09 PM
wells01's Avatar
Originally Posted by tuskyz28
what's the numbers? They mighty small on that graph
525/488
Old Nov 2, 2015 | 12:12 PM
DavidBoren's Avatar
528/488. Looks strong, probably is a blast to drive. Might need a 102/102 combo to get its full potential.
What exhaust system are you running?
Old Nov 2, 2015 | 12:22 PM
wells01's Avatar
[QUOTE=DavidBoren;19024408]528/488. Looks strong, probably is a blast to drive. Might need a 102/102 combo to get its full potential.
What exhaust system are you running?[/QUOTE
Kooks 1"7/8x3" to a kooks 3-4 ypipe with a merge and 4" muffex with the magnaflow straight through muffler
Old Nov 2, 2015 | 12:35 PM
DavidBoren's Avatar
Ok, nice. If you're at all concerned about it, you could get the 102/102 and add a cut-out to the exhaust, probably get 500rwtq out of it. But the numbers you have now, especially with the relatively mild cam, are decent. It probably drives nice enough now not to mess with anything for a while.
Old Nov 2, 2015 | 12:43 PM
wells01's Avatar
I plan later on to go with a low lash solid roller
Old Nov 2, 2015 | 12:50 PM
DavidBoren's Avatar
If you are going to jump to a llsr, I would definitely have true duals and the 102/102 done beforehand to best capitalize on the top end breathing.
Old Nov 2, 2015 | 01:49 PM
SoFla01SSLookinstok's Avatar
Graph looks awesome! Also with your combo not being optimized. I bet its real strong.
Old Nov 2, 2015 | 02:40 PM
wells01's Avatar
I haven't been able to drive it yet since being tuned other than normal driving due to the rain we have had, but I plan on playing with it today after work.
Old Nov 2, 2015 | 02:56 PM
Tuskyz28's Avatar
With 530 at the tire you'll run 10s easily on motor if the suspension is setup properly.
Ls2bait 416 ci setup made similar numbers and it hauled a$$!!
Old Nov 2, 2015 | 03:08 PM
wells01's Avatar
That's good to hear, I have all MWC stuff in the rear with Viking coil overs, right now with a full tank of gas the car weighs 3480 with me in it.
Old Nov 2, 2015 | 06:19 PM
Easy mid to low 10s driven properly
Old Nov 4, 2015 | 03:05 AM
Mazzenger's Avatar
Seems like it will scream. I second a cut-out.
Manual cut-outs are cheap and you will probably pick up 10-15hp and similar torque.
I wouldn't bother with a 102. It won't pick up much over the 92.
It would be an expensive swap for 5-10 hp in the upper rpm range.
Old Nov 4, 2015 | 07:40 AM
Rise of the Phoenix's Avatar
Nice job! You have the Mickey Thompson ET Street Radials?
