Down on power
2001 Trans Am M6 37k
SLP LT
Borla adjustable cat back
POTZ TB
K&N intake
On their mustang dyno it made 236 HP on the first run (4th gear). It felt like it took forever to complete the run. After it was over the owner comes over and says try this next one in 3rd gear. I felt kind of embarrassed.
If I can figure out how to upload the dyno graph the bottom lines were a 4th gear pull and the top lines were a 3rd gear pull.
What do you guys think? Where should I begin. I pulled a plug but I don't know much about reading them. From research the ground strap look nice with the timing mark pretty close to where it should be. Porcelain was only gray half way around you can slightly see in one picture. Volt meter on the cluster a needle width above 13. I'm not really sure what to do from here.
