233/239 TSP Cam and FAST 102mm gains
On a different note, I took the car for a drive yesterday and when I got back in the garage I notices fluid on my throttle body. It almost looked orange like dexcool which got me all currious. I did the old taste test and it didn't have any taste to it so I assume it just some condensation from the catch can where it goes into the TB.
So a little update, during lsfest west that I attended in May I was a little disappointed with my 1/4 times. I also had some great sounds coming from my 10 bolt after the event. I ended up having my carrier bearings being damaged in the stock rear. So I threw in a set of new bearings along with a set of 3.90 gears. I Also had the car dyno'd at a different shop as I was not feeling like my car was pushing 430hp with my track times. This new shop (JDP Motorsports) is much more into my style of racing (auto-x, road racing) as well. I was a little disappointed as my numbers dropped off nearly 30hp/30tq. With nothing else changing except the gear swap. Ended up with 405hp/361tq. I guess it's time for some heads!!!!
Just for fun I corrected your times for sea level. For your run in 7400 da I changed it from 13.9 to 12.9 in the calculator because even a 2.0 60' will knock a second off your quarter. At around sea level you are looking at a
11.6 @ 118 mph if that makes ya feel any better
