Expected power with an Lsa blower on a 5.3...
Old Nov 7, 2018 | 08:57 PM
  #61
Mgg4591's Avatar
Originally Posted by Nastboy
Any luck on those numbers? Been watching your videos on YouTube. Car looks and runs great. Looks to be a fun car.. I got all my parts now. Do you think the Corvette regulator setup will work with DW300(340 lph at 100psi fuel pump) on 93 with the returnless fuel rail setup? You got all my answers dude..
Sorry my wideband crapped out and Ive tried multiple replacement sensors but none are working, so I’ll have to find a new one.
Oh and I don’t see why not. As long as you dont need any more than the stock 58ish psi, it will work without a problem. If you ever need more than that you’ll have to replace it with an actual regulator.
Old Nov 8, 2018 | 01:32 PM
  #62
Mgg4591's Avatar
First run of the day with the new rear and tires! Gearing is spot on, crossing the line at the very top of 4th. I waited 20 minutes and went again but the clutch slipped badddd. Its a twin disk mcleod with probably less than 10k on it. Let it cool and babied the launch and it held, but my 60ft was trash. Gonna wait another hour and try again.
Old Nov 8, 2018 | 05:30 PM
  #63
AINT SKEERED's Avatar
If it is an rst, mine done the same. Go RXT or like me auto swap.
Old Nov 8, 2018 | 06:04 PM
  #64
s30.hybrid's Avatar
Nice! Looks like there’s opportunity to get deeper in the 10’s as well. I really enjoyed your build videos too, quality stuff!!
Old Nov 8, 2018 | 06:09 PM
  #65
Mgg4591's Avatar
Cool, Thanks! I couldn’t believe I pulled that off for my first run. After that the clutch started slipping, then I let it cool for an hour and didnt slip it as much on the launch. I then did two test runs to see if it was still slipping, and that yielded two 11.8s. After the clutch was ok I hot lapped it and did two 11.1’s. Then the 3rd honda for the day blew up and sprayed down the track. My launching was getting really crappy at the end of the day because they watered down the box too
much and it was spinning. Clutch feels fine now though, but I don’t trust it. Will need to updrade sometime next year.
Old Nov 8, 2018 | 06:24 PM
  #66
Mgg4591's Avatar
I think its an rxt but Im not 100%. If it’s failing its probably the rs.
Old Nov 10, 2018 | 04:16 PM
  #67
Nastboy's Avatar
Default Bypass valve
How you have your lines configured to close at work and open during cruise?
Old Nov 10, 2018 | 05:03 PM
  #68
Mgg4591's Avatar
I removed the solenoid all together and then connected the V side of the bypass to regular manifold vaccum. I left the bottom port on the valve open. At idle the valve gets vaccum and stays open. When boost comes up and vaccum goes down, the spring in the valve closes the butterfly.
Old May 13, 2020 | 04:03 PM
  #69
Mgg4591's Avatar
Default Expected power with an Lsa Blower, now with a 6.0!
I’m back at it again. The 5.3 kicked the bucket after playing with the 2 step at the track. Im assuming either the meth injection hydro locked it or 15lbs at 2600rpm was just a little too much for the gen 3 rods... Regardless that little 5.3 lasted me about 6 years! Not bad for a 300 buck motor off craigslist.
Anywhos, here’s the new setup. Any guesses on power? The car is going for tuning in a few weeks.
Gen 4 LY6 6.0
Summit Racing Pro Ls Forged Rotating Assembly
12cc dished pistons, static compression around 9.1
Cnc ported/rebuilt 823 Heads, Ferrea valves.
1 7/8 Speed Engineering Longtube Headers
3 inch Y pipe into a Flowmaster merge, single 4 inch Mufflex out the back with a Magnaflow race muffler.
BTR Stage 4 PDS Blower Cam
Lsa Blower with a Zl1 lid, reinforced cooler brick, .500 lid spacer.
Walbro 525 Hellcat pump, Siemens deka 80lb injectors.
2.4 Weapon X upper pulley, 9.17 ATI Lower 8 rib, lsx concepts race drive.
Ported snout with a Nick Williams 102 Dbw throttle body.
5 inch short ram intake
10 Gallon ice tank in the hatch running through a 26x15, 2.25 core, Afco heat exchanger from a Ford Raptor.
Same Aem meth injection using 50/50 boost juice. I replaced the controller with one that uses injector pulse width, in case the boost reference controller flooded the motor.
Strange S60 rear with 3.73’s and a tru trac.
Strange Chromoly driveshaft.
Stock 94’ ls1 converted t56 with around 120k... hehe
I’m using a Holley terminator X Max this time and so far I’m blown away with the drivability of this setup.
Best run on the old setup was a 10.8 @ 133 as shown previously. Put down 530rwhp on a Mustang dyno, 620ish converted to dynojet numbers. The car weighed around 3800 with me in it on the 10.8 pass.
I’m hoping for around 700rwhp Mustang numbers on the new setup!
Old May 14, 2020 | 11:10 AM
  #70
Summitracing's Avatar
LS1Tech Sponsor
That's a nice combo of parts you have there. Thanks for choosing one of our Pro LS rotating assemblies for part of the build. Make sure to update the community with the dyno numbers once you have them.
__________________
800-230-3030
www.SummitRacing.com
Old May 20, 2020 | 03:16 PM
  #71
caviness's Avatar
really nice looking car
Old May 20, 2020 | 04:35 PM
  #72
Ali Bin zayed's Avatar
Default LS swap
I have a Nissan Patrol 2003 I swapped the engine to an LS 6.0L with 6.2L heads and a 2.3 Whipple supercharge. I have faced belt issues like slipping and cutting, therefore I lost boost. I want a conversion kit from 6 rib belt to an 8 rib setup, Ending up making approx 12 psi of boost. Can someone please help me with this.
Old May 20, 2020 | 05:17 PM
  #73
I would contact Whipple and see what they would have available.
Old May 20, 2020 | 10:09 PM
  #74
They couldn’t help because of the swap ( dead end )
Old May 21, 2020 | 12:20 AM
  #75
Unless the swap vehicle construction interferes with the accessory drive, the swap should be irrelevant. Just ask if they have a 6- to 8-rib conversion kit. Don't tell them what it's in.
Old Jun 9, 2020 | 01:41 PM
  #76
Mgg4591's Avatar
Ok little update. I went for tuning a few weeks ago but unfortunately the dyno computer took a crap before my car could get up there. My new appointment is for the end of this month so fingers crossed!
Old Jun 30, 2020 | 06:55 PM
  #77
Mgg4591's Avatar
I made it to the dyno on Saturday but I kept losing fuel pressure after about 4200. It would dive from about 70 to the low 40’s and go lean. I realized the 525 I picked up was only rated at 60 psi, so around 70 it only made about 370 lph. I really need to swap in a -8 feed line, but for now I’m installing twin Aeromotive 340’s. The second pump will be triggered by the Holley under boost, so it shouldn’t stress the pumps too much. I’m trying to make a rental on the 13th so the larger feed line has to wait for now. Anyway the car put down 508/577 at about 4200 with no timing so far.
Old Jun 30, 2020 | 08:17 PM
  #78
chevymec's Avatar
Digging the build. Tried to keep up on YouTube but did't know you were on here. Ever thought about swapping out the front grill to the red bowtie one?
Old Jun 30, 2020 | 09:36 PM
  #79
Mgg4591's Avatar
Originally Posted by chevymec
Digging the build. Tried to keep up on YouTube but did't know you where on here. Ever thought about swapping out the front grill to the red bowtie one?
Thanks. I did but at the time I had my intercooler pump mounted behind the license plate, so I figured the rs grill can stay and cover the hoses. Plus my car was originally a sport coupe, so having the rs grill is kind of an easter egg to that. Whenever I decide to swap it, the red bowtie is the one I’m eyeing.
Old Sep 10, 2020 | 01:50 PM
  #80
ds98formula's Avatar
Awesome car. Any updates?
