Estimated gains with HCI swap in LS3 powered 01 Z28
I have an 01 Z28 with an LS3 swap. Currently has the Tick Stage 2 LS3 229/244 cam only and put down 432/408 thru a 4l60 stock heads and cam. Getting ready to installed a Mamofied Fast 102 along with a set of ported GMPP LS3 heads and Cam Motion Titan King cam 232/244. Trying to get an estimated guess on power with this set up
What's a auto eat up?? 20hp at most......even then it's way down especially in the tq department.
Heartbreaker dyno??....another 20 maybe. Well now you're up to what a fbo ls3 should be but still down 30wtq. 409wtq for a ls3 is down no matter how you slice if you have the supporting mods for your cam.
Then go run it and report back. Errybody's dyno is a heartbreaker.
The problem is i don't care where tick estimated them. Of course they'll be ok with not so great numbers when it's their stuff. Go to the track. A cammed stalled auto ls3 should have zero problems running 10s with any kind of traction at all. Hell a solid bolt on ls3 with a stall shoukd run 10s pretty easily.
BTW. ...what were the numbers before the cam? Have you ever ran the car?
What's the supporting mods on the car? ....valvesprings/headers/cat back/ewp/gear/9"?
I see you're on a stock ls3 intake. They are kinda poo. Especially in cammed cars. The long runner fasts are to. You need mid runners and spin dat bitch if you really want her to go.
Got any flow numbers for the heads? It'll most definitely help you up top as the stock heads run out of steam from my experience around 6300 rpm.
Stalled auto dyno numbers mean ****, if I were you I would tell everyone the lowest number possible that it made and then go and drag the **** out of them.
My Ls3 with a GMPP hot cam (LS3/480 crate engine) made 432rw/410tq through a dana s60 and t56. If you spec the combo right then I think you'll be closer to 500rw.
I ran the LS3 intake all the way up until 750rw on my d1sc setup. Didn't see the point or major gains of an aftermarket one at the time.
