Who has LS7 cam dyno graphs with cathedral port heads?
Why run a GM cam ? Billformula LS7 car has been mid 10s at 130 plus with a TFS 235 headed LS7 motor in a 6 speed WS6.
Moderator
Received 1,836 Likes
Originally Posted by big hammer
Here’s how I imagine a cathedral headed 427 Dyno would look like
Lol that post cracked me up.
Its a boat application I want to see where the oem intake valve closing point made those motors peak because its so far away from how Id do a cam in almost any application I dont really have much to draw from even though Ive done around 1000 custom cams for LS stuff since 2003. For this application though advanced about 8 degrees it should be close to the valvetiming I want, in a OEM smooth lobe, with cams I have free laying on the shelf
Actually, a cathedral head would often make more average power than 98% of the LS7 heads you see on these engines. The cross section of a 235-245cc head done right is more ideal than most of the ported LS7 stuff used on prob 97% of cars out there
I know this because the first NA 427 engine i built went 143 NA in a AUTO car with a OEM intake manifold on it untouched a decade ago. How many heads/cam LS7 STICK cars have been that fast since with ANY manifold on it?
Brian Tooley swapped LS7 heads to a cathedral port and picked up 200hp on a blower car.. The shape of the port is irrelevant, the motor knows only if the port is right size for application
All the FASTEST ones are racecars, period. You can read internet lists, I do these things day in day out before LS1Tech.com was created
Heres the fastest hydraulic cam NA car by far. He took the record from us quite few years ago. Its a 427 with... cathedral port 235 TFS heads
Again, the shape of the port is irrelevant
https://youtu.be/Zr2uADCkKnE
Well the difference is between those 2 cars is one of them is hydraulic roller and the other one is solid roller.
Not sure what's the weight difference is between those 2 cars.
Roddy Coleman car is now running a 440ci with TFS 245s by Greg Good and is running 5s in the 1/8 mile Naturally Aspirated with a hydrauic roller.
To each they own....
Lol
The orange camero is actually pretty portly. 3130 ish RW. Likely a lot heavier than the black camero
Moderator
No No No, solid rollers are just a gimmick
Your car is fast for a all motor car. If I run 10.2s with a 40x ci and you run the same with your 388ci what's the difference?
Their is a really fast cathedral headed car running low 4’s in the 1/8 now but they’re mast 295 cathedrals lol
You must read alot more internet lists than you build hammer. I know Judson, had lunch on him a couple times actually LOL, but that is the most wrung out NA LS car on the planet - worlds removed from what 99% of these things are doing its twin TB 10,400 rpm engine.
The heads needs to be APPROPRIATELY sized for the task at hand. Most arent tasked with going 4.30s in the 1/8 or 10k. The port shape has little to do with anything. If the shape alone was the answer, the square port LS3 would have been on the C6 Z but it sucked so they had to revise it.
You drew a picture of what you THOUGHT a cathedral headed 427 might do on Microsoft paint, Ive done it LOL
Ive seen that cam test artical, but its on a 5.3, and a long runner truck intake which is a little further away from design. I said eff it though and the LS9 cas are going in 8 degrees advanced, well 7 because the timing set is a little off
