Low dyno numbers
So I just had the car dynoed and it put down 339hp @5450 and 361ft/lb @3850
I was expecting this combo to put down something a little closer to 400 at the wheels. I know that dynos vary but this still seems pretty low to me. The other concerning thing to me is where the peaks happened. I thought peak HP should be around 6000 and peak torque around 4500 rpms.
The car seems to run well without any issues, but is seems like these numbers are from a more bone stock LS2.
Anyone have any insight as to what I should look into?
If you need more details about the setup just ask.
68 Firebird with T56 Magnum 2005 GTO irs 3.46 rear
Thanks
MSD has target air fuel set to 12.8 for WOT
340 Stealth in tank pump with return line set to 55psi
Here are the other two runs with timing settings for each
335.4hp @5250 365.6ft/lb @3550 28 degrees total timing
339.0hp @5450 361.5ft/lb @3850 30 degrees total timing
326.1hp @5300 357.3ft/lb @4050 32 degrees total timing
You might think you have low numbers, but it might be the dyno reading low. The track does not lie. What you car does there is what it can actually do. So until you can run at the track, we REALLY don't know what it's capable of.
As you noted in your OP, cathedral ported LS engine should peak torque at 4800 and HP at 6300 based on intake runner lengths, etc. It's actually quite a lot of effort to NOT peak there. Your peak torque is 1000 RPM low, which screams of a very early IVC. Carbureted intake changes things up some, but usually shifts the power band higher, not lower, due to runner lengths.
I think the peak torque at 360 is about right, but peak HP should be around 390 if the torque carries like it should. Cam with those durations should be something like a 116 LSA and 112 ICL. However, lots of times "Carbureted" cams end up with a 112 LSA and 108 ICL, which is fine if your durations are on the order of 230/240.
Short answer -- my guess is your cam or timing set is off by a tooth.
352 hp @ 5450 rpm 390 lb/ft @ 4050 rpm
