Man these TSP cams just make serious power. 419rwhp in 2nd gear converter unlocked. Mods are e85 with my PnP flex fuel sensor kit, 60 lb injectors, stock 243 heads, ARH 1 7/8" headers, Ms4 camshaft, and a fast 92. First pull I let off at 5900rpm laid down 412 rwhp but let off as the driveshaft felt a bit sketchy as well as 3.42 gears will top out around 160 mph on 3rd. So after did the pulls on 2nd. Same exact tune, made 407 rwhp in 2nd gear unlocked. I leaned it out to 12.8 and it picked up to 409rwhp. Leaned it to 13.3 and picked up another 2 rwhp. I decided to go back to 12.8 and added 2 degrees to have total timing ~ 31-32 and made 419 rwhp. We then sprayed it with a 150 shot n a cheap cold fusion plate and made 535 rwhp. This was in 99*f temps. Revved it to 7100rpm. Next mods are a chris1313 ram air intake and aftermarket heads.
