520rwhp N/A stock bottom LS1....
Thought I'd share my stock bottom LS1 (6) results. Been together several years and moving on now. So decided to share it...will give me something to look back at and remember the fun and aggravation I went through.
04Z
38K stock bottom
Modified Vararam
NW 102TB
Fast 102 (massaged by Tooley)
Deka 80lbers
TEA 243's (hand finished by Brian)
Stock rockers with trunnion upgrade
NGK TR6
Trend 3/8" 0.080" wall single piece pushrods
0.027" cometic
Cam = EPS 23x/25x 63x/61× on a 11x (very stable lobes)
Comp drop in short travel lifters (set at 0.010" cold)
Moroso vacuum pump (7" at idle/ 21" at max rpm)
Mezerie elec water pump
LG 1 7/8" super pros
Would usually shift somewhere around 7700rpm
Car had a massaged T56, RXT/ Fidanza and 4.10 gear
I'm sure I have forgotten something... lol
Car would trap 132+ in crappy +1000' DA @ 3000lbs-ish
Be happy to answer any questions or comments...
Here is one of many dyno graphs...made roughly 520/440
04Z
38K stock bottom
Modified Vararam
NW 102TB
Deka 80lbers
NGK TR6
0.027" cometic
Moderator
Received 1,837 Likes
Not bad at all!
Here's a tech question.....sbe LS1, 243s, cam is 230 234, .600 .602 111lsa, pacesetter coated long tubes, 6 speed.....with the LS1 intake the car made 365 365, which I think is low, I was expecting close to 400.....how much gain will I see from an LS6 intake? I'm swapping it out this weekend and taking it back to dyno.
But to answer your question....I would say 5rwhp and 5rwtq would be my guess as an average power increase (You could possibly see 10-15hp in specific rpm areas). Also expect your peak rpms to move up 200-ish rpm.
Example...if your 365rwhp peaked at 6200 and your 365rwtq peaked at 5100....expect the new hp peak to be 6400rpm and tq peak to be 5300rpm due to the slight differences in runner and plenum design between the two manifolds.
And there is a whole rabbit hole of discussions on how rpm gain can be beneficial.
Great results!
I have an 02 Z, and questions.
Which model of Fast 102? And did you need to change anything to get it to fit under the hood?
What valve springs did you go with?
Did you have any trouble getting the 1 7/8 headers to fit?
Thanks!
Thanks!
I run BTR .660 spring with his Ti retainer kit. Great spring kit IMO.
The LG 1 7/8" headers fit great....just take your time and hold your tongue right !!
lol...
Thanks...
Thanks for the info! Are you running stock-height motor mounts, or shorter ones for more manifold clearance?
Glad to hear it, thanks again.
More questions...
How are you driving the vacuum pump? I was thinking about a pulley in front of the crank damper / main pulley, but the steering rack is pretty close.
Also, what valve springs are you using?
Thanks again!
Thanks again!
Theres just enough room to slide a belt on and off.
Springs are BTR .660 with his Ti retainers...great kit from my personal experience. Zero issues up to 7700-ish...maybe closer to 8k..lol
But...I do pay attention to my valvetrain weight, rocker fulcum weight and preload !!!
Thanks...
D'oh, I just realized that I asked twice about the springs. Thanks for humoring me.
