Frustrated with forged bottom end H/C results.
Old 10-16-2018, 06:29 PM
  #41
chicofiebru's Avatar
Originally Posted by mOtOrHeAd MiKe
That cam is insanely large for the displacement, their Stage II would have been plenty. If money is an issue I'd go with a Dorman LS2 intake and a Warr 92mm throttle body.
Do you think the fast 102/102 combo is overkill or will it help?
Old 10-16-2018, 06:31 PM
  #42
Moderator
Darth_V8r's Avatar
Received 1,852 Likes on 1,152 Posts
Originally Posted by tech@WS6store
Youd be surprised how many "i want the biggest cam and most horsepowders the internet says i need" requests i get on the daily.
Alot of them are for 5.3s also because the internet told them a 5.3 is the same as a 5.7 only cheaper.
Putting a literal max effort donkey dick cam in something isnt going to give you what you imagine unless you are willing to go all the way with it, and that doesnt mean just cncing a set of stock heads.
100% agree. Those larger cams tend to need really good heads to perform.
Old 10-16-2018, 06:36 PM
  #43
Moderator
Darth_V8r's Avatar
A 102/102 is not too big for stock. Seen several guys running it on stock internals 5.7's. Scotty2000, BigHammer to name a couple. I ran 102/102 on my 5.7, which was heads/cam. Harder to tune for daily driving but not too big for the motor.
Large cams need compression. No way a website should recommend BTR4 for stock compression. BTR2 would be a far better match. Same with MS4. Tsp 228 a much better choice. And either would run fine on a 102/102 intake setup.
Old 10-16-2018, 06:39 PM
  #44
98CayenneT/A's Avatar
LS1Tech 10 Year
MSD 102/102 tb here and love it.
Light years above the anemic Ls6 intake obviously.
Old 10-16-2018, 06:47 PM
  #45
ddnspider's Avatar
Received 1,751 Likes on 1,307 Posts
LS1Tech 20 Year Member
Sell it all and go boosted.
Old 10-16-2018, 06:48 PM
  #46
pdxmotorhead's Avatar
If the voltage at the fuel pump end of the wire,, at load is more than a volt or so lower than the voltage from the battery + to ground,, your wire is too small..
For rear electric pumps I use a 80A relay and a #8 high strand count braided wire (I buy it at a local aircraft repair place.. or order it on line. ) One of the advantages of a
rear mounted battery.. You can run welding cable to the fuel pump if you want cause its close.
I also Fuses both ends of the wire,, one right before the tank, one at the relay.. With big wire comes big malfunctions..
Old 10-16-2018, 06:49 PM
  #47
LS1Tech 10 Year
I am taking this advice
Old 10-16-2018, 06:57 PM
  #48
Thanks for that info. Now talking about the cam, which cam could help me reach 450hp or get as close as possible, after I figure out the fuel issue of course. Do you think the 228r will be plenty for 450whp, or will I be better calling tsp for a custom cam? The car is not a daily driver, drive it around twice a week. Any other info on supporting mods you can give me will be appreciated. I know youre one of the wise guys here.
Old 10-16-2018, 07:02 PM
  #49
ddnspider's Avatar
Dang man, I didn't know that! Welcome to the dark side.
Old 10-16-2018, 07:05 PM
  #50
I'm thinking about it.
Old 10-16-2018, 07:07 PM
  #51
Good advice definitely!
Old 10-16-2018, 07:24 PM
  #52
ddnspider's Avatar
It will initially be highly frustrating and you'll have to work some bugs out and you'll find weak links.....but your first pull in boost will make it all worth it. These days the cost isn't even that much more when you factor in the expensive valve train for these big NA cams plus ported heads that can cost thousands and a FAST 102 or MSD setup that is a grand.
Old 10-16-2018, 07:27 PM
  #53
LS1Tech 10 Year
Ya, a bit hard to admit but the bug got me. Figured enough of being stubborn.
In the early stages but the converter will be coming out soon for a restall again for boost and getting a parts list and general idea of mock up going. Can do all the fabbing and welding so figured why not.
Old 10-16-2018, 07:29 PM
  #54
ddnspider's Avatar
I knew you'd come around eventually 😎
Old 10-16-2018, 07:39 PM
  #55
Ive been looking at the V3 turbo kit from HSP.
Old 10-16-2018, 07:45 PM
  #56
I think once I hear the bov sound I'll be turbo for the rest of my life.
Old 10-16-2018, 07:49 PM
  #57
ddnspider's Avatar
Their stuff gets better with each iteration. Seeing alot of NA guys going to HSP.
Old 10-16-2018, 11:14 PM
  #58
wannafbody's Avatar
LS1Tech 10 Year
I like my BTR stage 2 with ported 243 heads. Pulls strong all the way to 6800 rpm. Cam Motion Titan 2 would be another cam to look at. I made 400 rhp with a Dorman LS2 intake on a dyno a bit on the low side compared to what it normally reads.
I don't think there is anything to be gained with a MSD intake unless you are spinning to 7500 rpm.
Old 10-17-2018, 06:32 AM
  #59
ddnspider's Avatar
I <3 my Titan 2 in my LS6.
Old 10-17-2018, 07:58 AM
  #60
Kfxguy's Avatar
I did too. Lol
