How much power from this set up?
Im running a ford 8.8 rear with 4.10 gears
I was hoping to get a little more out of it. I did tune on the maf and with just 36” turn downs for the exhaust.
I think I’m going to try and re tune.
what do y’all think. True dual intakes? Get rid of the maf?
will running a full exhaust with mufflers help with back pressure?
* 85mm maf area is 5765 sq-mm
* 102mm throttle area is 8167 sq-mm
So, if you have a 4" CAI intake tract AND a 102mm throttle, necked down to a 85mm maf, you would not think it would be that restrictive, but as was said earlier in the thread... The heads and cam you have chosen can move a ton of air, and necking it down is like forcing it to breathe through a straw. It's 30% reduction in cross section area at the maf. In my builds, I try to always have the throttle be the limiting factor, since that's it's job - to control engine speed and power by restricting airflow ingress.
Now, here's the next problem. the 102mm card style maf blocks a huge portion of the flow area. So when you swap to a 102mm maf, you gain NOTHING vs a 85mm maf. This then causes the perception that the maf is not the restriction.
For a simple data check, ask the tuner what the map reading was at WOT at max power. If it was lower than ambient, you have an intake restriction - which again points to the maf and possibly the air filter/CAI being too small in addition to the maf. If the map was not lower than ambient, then i'm wrong. Simple enough. If that data is not available, another quick and dirty test is to pull the CAI, run on the dyno open throttle, and see the difference it makes. I figure with your exhaust being wide open like it is you might be surprised. I do find a X pipe does better than open duals, but only by a little bit. For the standpoint of why 440 and not 470 hp, the exhaust is not the issue.
Okay so I'll leave the turn downs alone. Now will I benefit from a dual true 4" intake? Or a single 4" intake will do?
I currently have a 3.5" single but it's more of a short ram intake I guess you can say. I was trying to post a picture of it on here but the app keeps crashing when I do so.
So I made the intake myself from aluminum piping from Spectre. I saw they have a 4" dual aluminum piping. I was thinking of going with that set up. What do you think? Duals or single? Since my car is an rx7 there is no direct fit one for it.
I found Spectre had the best options. What do you think?
Regarding data logging. I can take the car and do a 4th gear pull and log on dash command and see what my intake and map is reading out at WOT. I'll try and do that today and post the results.
Thank you guys for all the help!
Now, if you change your maf out but not the intake tract, you won't gain anything. you will need to up to 4" all the way from filter to throttle. I won't post a non-sponsor link, but there are sites dedicated to intake hoses. However you get it done is good. Might want to check out the CHRS1313 intake also. That might be a great approach for you.
I looked into the chrs1313. Looks like there is a promod version and a normal version. Either way I'm going to have to go with hood pins and some fab work to get that work.
Im going to see if I can get the measurements before i buy it. Price is very reasonable. It will cost me more to do a dual set up from Spectre.
The only plus side from Spectre is that I can get it to work without any fabricating.
Im gonna try and do some data logging tonight and see what I come back with
Okay so I just looked at dash command. My readings in the maf sensor has units of LB/MIN and the map at kPa.
Do I need to convert that?
Key on engine off should give you ambient on map. Then whatever you got on wot tells you your vacuum at wot
Pull #1
4500-5800rpm = 97kpa
5800-7000rpm = 96kpa
Pull#2
3600-4900rpm =100kpa
5000-7000rpm = 96kpa
Ambient fluctuated between 100-101kpa but seemed more steady at 100kpa.
I also had a question. What should he normal intake temps once the car is fully warmed up.
I have all this data. If you want I can try emailing it over to you.
Again, thanks a lot for the help man
