NA SBE LS3 Record?
Old Apr 10, 2019 | 03:21 PM
  #101
lazerlemonta's Avatar
I bet NHRA funny cars don't use 60 pound clutches........
Old Apr 10, 2019 | 06:33 PM
  #102
Darth_V8r's Avatar
Moderator
Originally Posted by HioSSilver
I think that optimal for drivability/acceleration and durability is in the 24-30lb range
I agree with high 20s for good all around clutch and flywheel combined weight
Old Apr 14, 2019 | 11:07 PM
  #103
scotty2000ss's Avatar
Looks good Phil! Good luck on the 26th.
I like what you came up with to make the short belt tight! It's not easy to get the belt on. Good idea man!
Old May 1, 2019 | 06:38 AM
  #104
Was not my best track day but heres what it ran on its best 2 passes. Hoping to get back to the track with some better conditions soon. 12-15 MPH cross winds and humidity of 78% I also had to add 60 pounds of weight to get it to 60' at all.
Old May 1, 2019 | 10:39 AM
  #105
62nalide's Avatar
What tire height and gear? If you can get that 60ft down to the 1.30s that be a monster for sure.
Best I went was 6.53 @105.11mph on a 1.38 60ft SBE L99 car tho.
Old May 1, 2019 | 10:48 AM
  #106
26" with 4.10s
Old May 1, 2019 | 12:56 PM
  #107
FinalCam's Avatar
Originally Posted by lazerlemonta
26" with 4.10s
What do you think is needed for 1.3x 60 foot times? A taller tire, wider tire, suspension?
Old May 1, 2019 | 01:00 PM
  #108
I have a clutch tamer I am going to try first. If that does not get me into the 1.4s I will try a 28x11.5x16 QTP. That 1.5 is spinning hard as well.
Old May 1, 2019 | 06:26 PM
  #109
Jtm2085's Avatar
What actual tire are you using laser? No doubt the extra roll out from a 28in will help. You really need a MT 3055s (28x10.5x15 stiffwall slick). Probably hard to fit though
Old May 1, 2019 | 07:05 PM
  #110
26x9.5x16 Hoosier quick time pro
Old May 2, 2019 | 07:13 AM
  #111
