TFS 220 Dyno LS1 SBE
Got a dyno graph from my recent build:
T56 6 Speed with monster stage 3 clutch
TFS 220 Tooley Blend milled to 61cc Chambers
.040 cometic
LS6 Intake
TSP 1 7/8 Headers
SE/ True Duals
K&N FPIK
Stock MAF
232/236 .600"/.600" 114 +4
Johnson 2110
Hotwire kit and Fuel Pump
42lb Injectors
What y'all think of these numbers? Mustang Dyno tuned by PAT G. You think I should go a fast 92mm and SD tune??? He said his dyno reads very low so I have no idea how to compare results and I have not gone to the track yet as I'm still on my OG 10 bolt.....
For future references~ its a stalled auto WS6 on board making 450rwhp (mustang dyno) with those heads and a smaller 228R camshaft but it does have a fast intake on it.
https://ls1tech.com/forums/dynamomet...hs-posted.html
Tusky
Johnson 2110
Something bad is happening right there at about 5700rpm where the power drops and the line gets erratic. Might be valve float. Where did you get the cam? Who set up the valvesprings?
Texas Speed ground the Cam, valve springs were installed at BTR. Does not seem to exhibit any issues....only thing I could think of is to use a longer pushrod? my preload was very close to the min for a 2110 lifter.
My TFS 220's from Tooley are 61cc as well, and I'm running the same lifters. I went with a 7.425 pushrod, which ended up being about .045 preload. A bit higher than Johnson recommends, but I have no issues and it's super quiet.
Edit - on preload, I like to aim near half the travel.
Your intake is your big choke point now
