My Dyno #'s on a 226/228 cam
354rwhp SAE and 340rwTQ
I've just got a few bolt ons and th rest is in the sig. I guess with some tuning, headders and some good S2 heads i hope to be in the 400 range. Plus i guess i'm running rich at 13.5A/F
Thanks to Todd at Strickly Dyno
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
actally, you're running a bit lean. I usually tune my car to be at 12.9-13.0 on a Dynojet which means it should be a bit leaner 13.3 or so on the street.
I'm guessing that you have no tuning done to the car. Tune the car and I would expect you to pick up another 10 rwhp if not more. I would guess that 368 or so with stock manifolds, cats, and stock catback.
Another easy set of mods would be ORY and cutout. that should get you into the 380's SAE with tuning.
Originally Posted by STMPDUST
Kennys car made very good power considering the rev limiter is at 5950 rpms, the power curve was still on its way up till it hit it.
Todd
Todd
Thanks Todd for doing the dyno run on it, One of these days i'll get the rest of my mods on. By the way i bumped it up to 6500 too
Originally Posted by Drew98TA
A little off topic, but what does the +1 on the lsa mean? I've seen this on other cam specs but have no clue as to its purpose. Thanks in advance.
You know i haven't got a "clear" answer on that either. That's just the cam i got and i could take a "guess" on it. Maybe it winds up faster than just a "plain" 113lsa, not sure though
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
SN95 Director
check the cam guide in sig.
