L99 bolt on hp dyno sheet
Find Richard Holdners Speed secrets vid on 500hp builds and skip to the 9 min mark, maybe I’m missing something?
I usually respect and appreciate your posts here due to you actually being a builder. But once in a while you get your head in your *** and say $hit like the above. You are a legend in your own mind....
I've seen LOTS of dyno tests, Holdener or otherwise. A good database from which to gain what knowledge I have. I don't need to build engines to do that....
I know every nut and bolt in an engine, and could assemble one out of a tableful of parts and a torque spec sheet.
I still stand on my above statement that one need not be a builder to know how to read/interpret a dyno chart. Just statistics in graph form.
BTW, this thread started out being about the L99, then drifted into the LS3, a very different engine with different cams and compression ratios, plus AFM/DOD and VVT on the L99. Discussion of one has few parallels with the other, performance-wise. The L99 has far more in common with all the 6.2L truck engines, including the cam.
LS3 with HEADERS, ELECTRIC WATER PUMP, NO ACCESSORIES & TUNE...NOT A STOCK L99
GAtsma you did say “ I don’t see a bone stock LS3 making near 500” in box #11. So you could have made a distinction right there, you kinda doubled down saying that about an LS3..... Just because you pushed a broom around the shop, held the light for a mechanic and learned the names of parts does not make you qualified for anything, really
minitryker, you stated an LS3 with a cam could make 500, that’s common knowledge, I contend they don’t need a cam replacement to do it, and they don’t 495/490 is pretty close. I never mentioned L99, I said LS3 way back there. Yes, I’ll I agree that you did say L99 back there, so I was a little off topic but correct.
And there ya go being a dick again. Have I ever built a whole engine by my lonesome? Nope. Does not mean I haven't done most of the major clearance checking and assembly steps while helping build an engine. I have just never been in a position where I need to build numerous engines.
If you do that for a living, fine. Either that or yours don't live and require repeated RE-building. Practice makes perfect, after a while. Or supposed to... LOL
