Question about my dyno
https://ls1tech.com/forums/dynamometer-results-comparisons/194316-do-these-numbers-sound-right.html
On my dyno sheet, the horsepower fluctuates at the top of the power band starting at about 5500. It goes up and down rapidly in about 5-10HP bumps from 5500 to the rev limiter. Any idea as to what is causing it to fluctuate?
Mods are in my sig.
Thanks in advance.
My tuner said that some cars do this and it's nothing to worry about. You can't feel it at all in the car when driving it.
-Matt-
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Thanks in advance.
Good luck...
Tony M.
Good luck...
Tony M.
Some of you guys could be right, maybe the springs are getting weak. I've seen this before on other cars, even some cammed cars with better springs but after looking at his graph again, maybe it is a little much.
Dale, once you get that cam, you'll need new springs anyways. get that car to the track!!! Does your old graph show this?
What doesn't make sense is that it only does it between 5500 and 6000 and not above 6000. I would think it should be doing all the way to the limiter.
Bill, do you have a scan of the car that dyno'd after me? You said his did it a little also. Could the dyno be vibrating since it's a mobile dyno? Probably not, but I figured it might be worth bringing up.
I was back to the track yesterday. I ran a 12.81@109 on street tires with no change in air pressure.
I don't think I'm going to worry about it until it's to the point where I can feel the power fall off. I should have a cam in it before then anyway.
