4.8l turbo results
4.8l turbo results
SBE 4.8l
~9.6 CR
Huron Speed v3 ac kit
VS Racing 7875 billet 1.25ar
bumper exit 4" DP
summit stage 2 turbo cam
ported ls6 intake
ported 243 heads
~17psi
e65
12* timing
m6
enjoy.
~9.6 CR
bumper exit 4" DP
ported ls6 intake
ported 243 heads
~17psi
e65
12* timing
m6
enjoy.
The following 5 users liked this post by beau.:
ALL ULL C (03-30-2023), thefast1 (03-28-2022), Woodylyf767 (03-31-2023), wretched73 (03-28-2022), z28_YOU_HO (03-30-2022)
I agree. Very nice. How many miles on the short block? Did you regap the rings?
i was told it was a pullout from a 2011 gm truck that had ~160k miles. i pulled the heads to put my ported 243's on it and trimmed the truck windage tray to fit an f body pan. i didn't touch the SBE. rings and rod bolts are original. i have a little over 4k abusive miles on the build.
The following users liked this post:
thefast1 (04-26-2022)
Good numbers! I’m looking for around 800wheel (900 if I can) out of my 4.8l Silverado build. 180k SBE 4.8l BTR stage one Turbo cam ported/ big valve 706 heads, TBSS intake, Trick turbo kit, VSR 7875 billet with gen 3 85mm race cover upgrade. Had it on the dyno once last year and it maxed my single fuel pump around 13psi at 630 wheel. E70 content.
This year it got a Holley terminator Xmax ecu a second fuel pump, bigger injectors and some methanol injection for extra insurance. Unsure what it will do…
any reason you stopped at 17psi?
Monster stage 3 clutch. If I had to guess, ~8k miles on the clutch, ~5-6k of those miles with the turbo. T56 is holding up thus far... more concerned about the stock driveshaft and 10 bolt which are also holding up ... for now.
The following 2 users liked this post by kinglt-1:
beau. (05-20-2023), Old Buzzard (04-04-2023)
the more cylinder pressure you make, the more stress you're putting on the motor and the higher the chances of failure. you'll get answers to this question based on what others have done or seen, but you're not getting an accurate description of their setup whether that be fuel type, timing curve, boost curve, their definition of a "stock longblock" or "reliable", weight of vehicle, dragstrip vs overdrive hwy vs dyno pulls in mexico, etc, etc. it's all relevant.
seemingly this is going to be a budget build because you're wanting to push a stock longblock to it's limits. if you're paying someone to build the car for you, my suggestion would be for you to find out who you want to build it and, if you're there, talk directly to them about your budget and your goals. if you're going to build the car, i'd suggest you start a thread and provide information on your setup, your goals, and your budget with as many details as possible so you can get better guidance on your build from people that have already been down that path.
-beau
