99 T/A Cam only 435/388
Results of my wife's cam only setup, she has had the car for 18 years.
Stock 99 ls1 SBE A4 on 93 oct fuel
1 3/4 long tubes w/ 3 inch true duals
EWP
Ported mamo fast 102 w/ 103 tb w/ 4 inch intake tube for SD, but still running a Lid for now
ATI 10 percent balancer
12 bolt w/ 3.90's
243/247 623/623 camshaft specd my pcm of nc
Gtp injectors
Yank pt4000
Made 435hp @6500rpm & 388tq @4700rpm today. Before it made 417hp @6200rpm & 384tq @5100rpm with ls6 intake and 3.73's in the 12 bolt. Went a best of 10.79@123mph with the ls6 intake. Ill see if I can post the graph.
EWP
12 bolt w/ 3.90's
Gtp injectors
Yank pt4000
The following 4 users liked this post by Shadow02SS:
BFromTheD (02-25-2024), DualQuadDave (02-26-2024), Ls7colorado (03-02-2024), SLP IROC-Z (03-25-2024)
EWP
12 bolt w/ 3.90's
Gtp injectors
Yank pt4000
EWP
12 bolt w/ 3.90's
Gtp injectors
Yank pt4000
KW
The following users liked this post:
Jimbo1367 (08-13-2024)
01FormulaTA (03-26-2024)
They're all wrapped under the term cam only. Come on guys. Nobody thinks cam only literally means the cam was changed. By that logic you couldn't do pushrods or valvesprings. Cam only literally means boltons plus a cam, no heads or or bottom end work and its always NA. This is the generally accepted definition for decades.
brutalzo6 (03-03-2024)
The 376/480 crate motor I bought from GM was “cam only” … it had a GMPP Hotcam in place of the stock LS3 cam. So there’s an example of a cam only (by my definition anyway) engine in the real world.
I’d say this engine wasn’t cam only, but cam + boltons. Doesn’t matter, I’ll know to clarify in the future since some of you are playing fast and loose with the language 🤣🤣🤣
G Atsma (03-03-2024)
I did 🙂 … but I’m an engineer, and we tend to operate under the assumption that words have actual meanings.
The following 3 users liked this post by ddnspider:
“Cam only” means EVERYTHING except heads. Silly term isn’t it?
It made 417 with an LS6 intake and stock cam or was the 417 part of the cam only as well?
Abs (04-05-2024)
Y2K_Frenzy (03-25-2024)
