Post your Dyno numbers here (N/A, NOS, FI)
Old Jan 9, 2005 | 02:52 AM
LSs1Power's Avatar
Default Post your Dyno numbers here (N/A, NOS, FI)
We didn't do this for a long time now and we have alot of new setups in the past few months. Its nice to see what everyone has now. Everyone post the following:
1. Engine/Exhaust setup (LS1, LQ9, Heads, Cam specs, etc...)
2. Fuel Setup (42 lbs injectors, Intank fuel pump, etc...)
3. N/A, FI or NOS (Please say what you are running in details if u can).
4. M6 or A4. (what kind of clutch or verter setup you are running).
5. Rear/Drive Shaft Setup.
6. Dyno number and graph if handy.
7. ET with race weight if u ran your car before.
Old Jan 9, 2005 | 02:53 AM
LSs1Power's Avatar
I will start:
1. Stock heads and bottom end 346 LS1 with FM7 cam (224/230 .587 .593 114LSA) and PRC dual springs/ FLP headers with hooker catback.
2. 60 lbs injectors and 255 intank fuel pump running 60psi of fuel pressure.
3. ATI 8 rib seeing 8psi from 7.65 crank pulley and 4.25 SC pulley.
4. M6 running Mcloed Kevlar/Organic with steel flywheel and adj master. (Slipping bad now).
5. 8.8 rear end with Eaton posi, 3.73 gears and 3" Chromoly Drive Shaft.
6. 548rwhp 499rwtq with 19 degree of timing and low 11's AF ratio. This dyno sheet shows stock VS now. http://www.msnusers.com/CarsRelatedG...oto&PhotoID=60
7. Didnt have a decent run since the clutch is slipping but the car ran 12.3 at 123mph with 2.3 60ft shifting around 6000rpm instead of 6800rpm. Race weight of 3800lbs didn't help the wounded clutch too.
Old Jan 9, 2005 | 03:15 AM
BADBOYZ28's Avatar
1. Stock heads and bottom end 346 with TSP 231/237 .595/.598 112 LSA with 918's springs & Hooker LT's w/ custome 3" x-pipe
2. Stock 26lb. Injectors (poped really bad most of 60ft. just upgraded to 28lb. injectors)
3. NOS 5177 Dry Kit (100 shot)
4. A4 with 3800 Vig.
5. Stock 10 bolt w/ 3.73's & stock driveshaft
6. Dynoed 356 rwhp/333 rwtq (n/a & TR 224/224 cam) new setup numbers to come!!
7. Old setup N/A-11.98 & NOS 11.00 3600 lbs. race weight
Old Jan 9, 2005 | 05:02 AM
Pewter_LS1's Avatar
LS1..... Hotcam, Pacesetter Long tubes, Mufflex Y, Electric cutout,Lid Tuning by CAM
Stock
N/A (Nitrous in future plans once I achieve 400 hp N/A)
M6 Stock
Stock
Base line was 321.5hp and 339.5tq
Numbers 390.9 hp and 385.8 tq
Nothing to brag about
Old Jan 9, 2005 | 07:46 AM
Kurtomac's Avatar
2002 WS6 Stock bottom, TEA S2 5.3s FMS F13(230 232) MTI lid, TPIS 90mm FAST 90mm, Jet Hot LTs Mufflex ORP Cutout
stock 28.8 injectors, walbro 340lph intank pump(got a NX Kit havent used yet)
NA, not numbers on the spray yet
Moser 12 bolt 390s Eaton Posi, 3" ape chromoly driveshaft
446rwhp 405rwtq
11.60 at 119.5 on a 1.68 at aprrox 3600lbs
Attached Thumbnails Post your Dyno numbers here (N/A, NOS, FI)-techdyno.jpg
Old Jan 9, 2005 | 08:08 AM
beardWS6's Avatar
H/C from MTI S2 heads and Y1 cam with stock bottom 346 all bolt-on`s
150 wet shot TNT F2 kit
441 rwhp 403rwtq N/A
650 rwhp 655rwtq 150 shot
This is with 12-bolt-3.73 gears, Vig 3800.
Everything in Sig!
Old Jan 9, 2005 | 11:59 AM
1 fast camaro's Avatar
Everything in Sig!
damn, thats a lot of power through an A4, congrats
Old Jan 9, 2005 | 12:17 PM
-Q-'s Avatar
-Q-
Mods are in the sig, just bolt-ons.
340 hp 352 tq on hot motor (6th out of 6 straight pulls with no cool-down)
Attached Thumbnails Post your Dyno numbers here (N/A, NOS, FI)-final-tune.jpg
Old Jan 9, 2005 | 12:24 PM
beardWS6's Avatar
Man you should see how she runs. The power I get and the flat TRQ curve I have is plain sweet. The Nitto`s hate it from a 20-30 roll. I haven`t sprayed yet on the street! But it will be sweet!
Old Jan 9, 2005 | 01:23 PM
JoeyGC5's Avatar
1.) Patriot 6.0 liters (59cc), MTI C2, TTS longtubes, no cats, Slp loudmouth
2.) SVO 30lb'ers, racetronix intank pump.
3.) Bottle going on when clutch swap happens, TNT F1 kit
4.) M6 stock 3.42's, Gonna try the Ram HD pretty soon
5.) Vette
6.)429hp 405 tq with 27 degrees timing and 12.7air/fuel
7.) Race weight with me is about 3350, Only time at track with this setup went 12.4 @116.8 consistently with a blown headgasket
Dyno before retune, needed to lean it out.
Old Jan 9, 2005 | 01:46 PM
regorih383's Avatar
nice power
Old Jan 9, 2005 | 05:16 PM
Avengeance's Avatar
1) LS1 stock everything motor except cam and valvetrain. TR224, 918s, Ti retainers, TR PRs, YT 1.7s. Exhaust.. Jethot LTs and ORY, Cutout, Spintech Muffler.
2) Stock.
3) N/A - bolt ons, not all but most.
4) M6 - SPECIII, Fidanza Alum FW, Pro5.0.
5) Stock
6) https://ls1tech.com/forums/dynamometer-results-comparisons/229328-my-dyno-s.html
7) When I was @ 344rwhp I did 12.8@110 1.9 60'... this was my second time ever driving the car at the track. Havent ran with current numbers.
8.) SC numbers coming soon.
Old Jan 10, 2005 | 12:31 AM
GrannySShifting's Avatar
Hey Feher, we cant see that dyno pic
Old Jan 10, 2005 | 01:02 AM
LSs1Power's Avatar
I dont have a scanner so i had to take it with a digital camera. Hey NOS guys it would be nice to know how much timing are u guys running N/A and with NOS.
Old Jan 10, 2005 | 07:55 AM
CarsRFun's Avatar
1999 Corvette FRC
Stock Heads - Supermaxx Longtubes, highflow cats, and X-pipe, Blackwing and MAF *just took the maf off to get ready for LS1edit*
26lb stock injectors AF was 11.9
M6
3.42
326/340
Have not gotten to the track yet.
Old Jan 10, 2005 | 10:05 AM
Heres a turd of a car
2002 WS6 6 speed
346/369 ft lbs 12.50 @ 112 full weight Eagle F1 tires
Headers, ported TB
Old Jan 10, 2005 | 01:27 PM
Ryan02SS's Avatar
02 LS1 w Patriot Stage 2 5.3L Heads, stock bottom end, TR224 112LSA
Stock 28.8lb injectors
All motor
M6 w self rebuilt T56 upgraded steel 3-4 shiftfork, New Z06 clutch
Stock 10 bolt w 3.42s @ stock driveshaft
416rwhp @ 391rwtq thru Cats with all mods in sig
Only ran twice at track and best time was 12.8 @ 114 mph 2.4 60 ft!
Car will not hook off the line on street tires and on the 1-2 shift it blows the tires off and hits the rev limiter causing me to lift off the gas. Best MPH is 116.8.
Old Jan 10, 2005 | 08:04 PM
Black02SS's Avatar
Post
1. Stock Heads, Stock TB, Stock Pulley, 224/224 .581/.581 112, Mac Headers, SLP Dual/Dual Exhaust
2. Stock
3. N/A
4. M6 (Stock)
5. 10 bolt. Stock 3.42's
6. Before with SLP lid and after with mods listed above.
1. Same as above but 3" True Duals and Shanner S2 TB
2. Stock
3. N/A
4. M6 (Stock)
5. 10 Bolt. Stock 3.42's
6. Before with mods listed above and new mods.
1. Same as above
2. Stock intank - 255L Inline
3. TNT F1 with 100hp Jets
4. M6 (Spec Stg 3)
5. 12 bolt with 4.11's
6. Before with mods listed above and new 12 bolt.
1. Same as above except added TEA Stg 2 5.7L Heads (Milled .030)
2. Same as above
3. Same as above
4. Same as above
5. Same as above
6. Before with stock heads VS. TEA Heads
With 100 N20 jets and 150 Fuel Jets
1. TEA Stg 2 Heads, FM11 (228/230 .575/.595 114+4), SLP Lid, S2 TB, Flowtech Headers, Hooker Exhaust, 78mm LSX Intake
2. 255L Intank and 255L Inline
4. M6 (Spec Stg 3)
6. Before with mods listed above comparing to new setup.
Old Jan 12, 2005 | 11:46 AM
keliente's Avatar
[QUOTE=LSs1Power]We didn't do this for a long time now and we have alot of new setups in the past few months. Its nice to see what everyone has now. Everyone post the following:
1. Engine/Exhaust setup - 01 LS1, air lid & magnaflow exhaust
2. Fuel Setup - stock
3. N/A, FI or NOS - n/a
4. M6 or A4 - M6 stock clutch
5. Rear/Drive Shaft Setup - stock steel driveshaft
6. Dyno number and graph if handy. - 310hp/329tq STOCK, haven't updated
7. ET with race weight if u ran your car before - no idea
Old Jan 12, 2005 | 08:55 PM
MAD COW's Avatar
[QUOTE=keliente][QUOTE=LSs1Power]We didn't do this for a long time now and we have alot of new setups in the past few months. Its nice to see what everyone has now. Everyone post the following:
1. Engine/Exhaust setup -WS6 02 LS1, Quarter Mile Performance Air Lid,SLP Mass Air Sensor, Smooth Flow Bellow, Modified y-pipe, & Magnaflow Exhaust
5. Rear/Drive Shaft Setup - stock driveshaft
6. Dyno number and graph if handy. - 321.64hp/347.53tq (SAE) smoothing with mods. Used 91 octane gas. Dont have stock numbers.
7. ET with race weight if u ran your car before - I have not raced the car with mods and dont have race weight.
