Has Anyone Gained Power Switching from Duals Back to a Y-Pipe?
Just curious if anyone has ever gained power switching from true duals to a Y-Pipe setup with a cutout.
Josh
Josh
Originally Posted by 2MuchRiceMakesMeSick
No way. Even if someone did it would be peak power and not under the curve where it counts.
i couldnt agree more, after i took my duals off and went back with my borla i could tell a big diffference the first time i smacked it. i was like damnit!! thats why im going back to the duals. :-)
It would be nice to have a dyno overlay of a car who went from one to the other to see the way the power curve is affected. I have dual cutouts and will have my car dynoed again soon. I am going to do this on motor to see how the curve looks through my borla sportsman and basically open headers. I expect to see a noticeable and then nominal drop in torque until about 4500 rpm and then a good gain in the upper rpms where it counts.
Originally Posted by SouthFL.02.SS
I've gone back to a Y-pipe. Hope to have numbers soon. Car's been down for repairs (it's been a while).
!LS1 11 Second Club
Originally Posted by Turo
Mind if I ask what made you change? I was considering going back due to ground clearance, but I think I am going to keep the duals after all.
I've gone to a QTP Dual Elect. Y + SLP 2OTL Catback. Loud when I want loud, quiet when I want quiet. Flows well both opened and closed. I even think it sounds better than the 3" True Duals X dumped I used to run.
!LS1 11 Second Club
Originally Posted by Damian
Dont remember, it's been a while. Duals may pick up a tad bit in the midrange on most cars, but it's not "that" great over the Y setup like some people think. The Y is pretty efficient as long as it's a 3 inch with a good collector.
Yes, a good merge is key.
3" TD's here. Can't see picking up a nickel goin from TD's to a Y. The gains w/a TD/x system vs. a good Y setup may be only marginal on a 346, but on big cube bottoms, TD's are the only way to go IMO..... not to mention the sound can't be beat.
As far as it being too loud....put real mufflers on it, or.... you could always drive a minivan....
