g5x4 cam only dyno
Excellent question.
22-24* of timing on a cam only car is a joke, and you know it. I can see you running this low timing for a safe n20 tune, but for an NA cam only car, it's assinine.
timing isnt everything and a lot of people dont want to retune once every 3 months when temps change... Most would rather know if they get a bad tank of gas or hit a really crappy air day they dont have to worry about detonating or having driving issues, I have a few LS1s on my floor if you would like to see what too much timing looks like!
Continue...
Continue...
LOL... but a 9 second car and 2 that are well into the 10's dont count right?
Continue...
My car has been dyno'd at ADC as well as our dyno and makes numbers within 1-2 rwhp of each other. I did 406 at ADC about 6 months ago, then on a before/after at pro dyno did 408 which I will say is more than likely due to daily temp variances, not dyno.
also keep in mind our dyno is identicle to ADCs and Xtremes... both dyno jets, both on the same software, so unless the magnetic north of the world changes then both dynos will do the same save for differences in daily readings... there is NO CALIBRATING A DYNO!
Makes sense now that we know you are talking about a smaller chambered head and more compression. As I said, a cam only car in AZ will have no problem running 28* of timing. Glad you agree.
Also who ran consistent 14.0s at the track with that hp? there are a few bad drivers that just dont know the cars that well, but the majority of good drivers run low to mid 13s with that power... I did consistent 13.11@109.5 with 337 rwhp so I know its possible, and that dyno was done at Street Flight WAY back in the day before I had even ever gone to pro dyno... If you had a bone stock car and went to Xtreme, ADC, Us, and to any other dynojet chances are all would be within a few horse of each other... main difference is our dyno is indoors as well as Xtremes, while ADC is outdoors... that 10 degree difference in temperature can make a lot on a dyno!
See my post above.
