g5x4 cam only dyno
See my post below.
The thread wasnt started by myself and i never said cam only either.
Proof that timing isnt everything. Personally I believe volumetric efficiency and cylinder compression are more important than timing. Bad timing can stuff all that up. IMO timing is a byproduct of maintaining optimum balance between these 2.
That and good fuel.
...the dyno looks real nice. However i was under the impression that this cam was designed to generate a little more torque in the low/mid range.....sort of trying to overcome the G5X3's shortcomings. I know it's a big cam so i shouldn't expect great low end numbers, but it really just seems to be lacking in the low end.
Exactly why I posted the way I posted. The heads havent been worked nor have they been milled! Thats like saying a cam only z06 isnt cam only because "it has ls6 heads....." . The reasoning for low torque is because of how rich it is in the low/mid It's more of a conservative tune as I was told. It was also using heavy *** zr-1's with 315's so im sure that doesnt help. Thanks again to mike for posting the graph
At least after all that, we know the actual mods the car has.
