View Poll Results: HoW much RWHP are you making?
Voters: 3766. You may not vote on this poll
How Much Power Are You Making @ The Wheels?!!?
Finally some dyno numbers well for one car
02 Trans Am WS6 A4
SLP Flowpac, SLP MAF, QTP LT's, Catted Y and GMMG NGK plugs, Taylor Wires, computer tune on a stock stall, stock gear stock suspension
327rwhp/342 rwtq on a Mustang Dyno
359rwhp/376 rwtq on a Dynojet!
Now all i need to do is finish the bolt ons! then what?!?!
02 Trans Am WS6 A4
582 rwhp@8300 rpm , 543rwlbs/ft @ 6000 rpm Naturally aspirated ( I'll keep the nitrious numbers to myself) on a dynojet.
Engine is in a 1995 Z28
421 SBC Dart 18 degree motor with all the toys(not EFI).
Car ran 10.38 @ 138.8 on the motor in nitrious trim with a glide
I know its not an LS1 but hopefully it is interesting for comparison sake.
Vince
Vince
2002 Z28 with 29,800 miles. Mods are lid and magnaflow muffler. I made 4 Dyno pulls Trying To Prove the worth of the hand held Tuners.
First pull with Hypertech Power Program made 303.04 Max Power with Max Torque 331.50. Run Conditions: 71.42 degrees, 30.14 in-Hg, Humidity 31%.
Second pull Using Stock Program made 311.04 Max Power with Max Torque 326.95, Temperature at 74.31 degrees
Third pull was with new Predator, version 2.11, made 311.30 Max Power with Max Torque 326.53, Temperature at 75.15 degrees
Fourth pull was made with the Predator, Lid opened up, made 312.59 Max Power with Max Torque 327.57, Temperature at 78.57 degrees.
In summary: the Hypertech run had a Torque Spike that resulted in the higher reading. The torque fell off starting at about 4200rpm. Also Air/Fuel ratio was 12.17 fairly flat across the run. Most Importantly, the Predator and Stock Programs were identical with an Air/Fuel ratio of 12.55. The Dyno Chart shows one line from 3500 rpm all the way to 6000rpm. I suspect the Predator could be leaned for another 10-12 horsepower.
I Dyno'ed mine @ Precision Autosports in Dayton, Ohio last Friday, After 5 Pulls with the torque converter unlocked and a 16+ A/F Ratio, I managed 310HP, 325.5 Ft-Lb Torque. Not bad for the mods I guess, couldnt get it tuned there b/c they dont have Fbody programs yet. This was on a dynojet.
I was very Impressed with these gains, my first Dyno I put down 300.55 whp and 320 tq with just a lid and filter, I went back with the SLP Loud Mouth and put down 320.95 whp, and 339.43 tq, pretty awesome gains.
