View Poll Results: HoW much RWHP are you making?
Voters: 3763. You may not vote on this poll
How Much Power Are You Making @ The Wheels?!!?
#441
![](http://temp.corvetteforum.net/c5/chuckharmon//427_ls7_dyno.jpg)
LS7 4.155" bare block, Eagle forged 4" crank, forged Manley rods, 11:1 Mahle forged pistons; 228/230 comp cam, 114 lsa, .591" lifts, AFR 225 65 cc heads, C5ZO6 stock intake system, LG long tubes w/ high flow cats.
#443
91 camaro, F1-R blown 383 stroker with AFR heads and a bunch of other poo intercooled, meth injected......tremec tko 600 5 speed, moser 12 bolt......only 20psi too.....the car was breaking up at 6600rpm + so we never made it to 7500, where the cam should peak and the blower is at max output
827.08hp 688.38 ft/lbs
![](http://i51.photobucket.com/albums/f391/383backinblack/827vs8204-6-07.jpg)
#449
87 IROC street/strip, 421 sbc, DART block, GM 18 degree heads, 2 76's, non-intercooled, 10 psig springs in the waste gates. 1011 RWHP @ 6200 rpm.
Well its a little on the rough side and theres still some tuning to be done to smooth it out, but it should be up a little higher with more fuel and RPM.
Latest Dyno Jet pull on 4/30/07, 1076 RWHP @ 7200 rpm. Had a little more heat in the engine this time, but smoothed it out a little up top. The dip between 90 and 120 mph is the tires breaking loose on the rollers. Still has good street manners, will see if it will hook at the track this weekend.
#454
2002 Z28
Hardly any mods yet
Full custom OS dyno tune
Gutted Cats
Dumped exhaust
301rwhp / 341 rwtq
New mods coming:
383 Eagle Stroker Kit (balanced / blueprinted)
Forged Pistons / Rods / Bolts
100 shot N20
Hooker Longtubes
1.8" Lifters
Comp Cam (1500 - 5500 rpm)
.... and thinking about STS Turbo
Mike
Hardly any mods yet
Gutted Cats
Dumped exhaust
301rwhp / 341 rwtq
New mods coming:
100 shot N20
Hooker Longtubes
1.8" Lifters
Mike
#460
1 Post
Had to come back and update with the new Cam and ported 90mm Fast and tuning from LG Motorsports. 486 rwhp 451 rwtq N/A 346 ci
Just a bad as H/C/I + bolt on car from LG Motorsports
www.lgmotorsports.com or by phone 1-972-429-1963
