potential setup, few questions
car to start from: 2000 T/A (non ram air), a4.
1. Patriot Stage II Center bolt LS 4.8-5.3L Ported Heads Assembly
2. TR224 on a 114 lsa
3. Vigilante 3200 rpm stall torque converter
4. magnaflow catback
5. 90mm LSX f.a.s.t. intake & 90mm TB
6. a lid. haven't decided which, but from what i gather a lid is a lid
7. autometer dual guage setup (will need to know tranny temp because of the stall, for instance)
8. a tune by TTP
what do you think of this, and what are the times do you think i could expect from this setup?
also, what will the drivability be like? will this sound like a sewing machine? will it eat more gas than it already does (even stock it eats quite a bit, since its an a4..)?
any more input?
thanks for whatever you guys will, without a doubt, dish out on me..
Also, I didn't notice a set of LT headers in your list. I wouldn't waste my time doing heads & cam w/o a set of LT's - you'd be leaving plenty of power on the table.
Seems kinda mild to me, I would opt for something slightly bigger like a TSP Tourquer. Again, your call.
TSP Tourquer: what are the specs on that cam? and the reason i went (at least in my mind, so far) with a 224/224 on a 114, is because this is a daily driver (except for snowy days). i also dont want my valve train sounding like i have a textile mill under the hood.
how does the tsp tourquer make the valvetrain sound? and is there much lope ?
LTs yes.. i forgot to list those. sorry. although, i'm still not sure whether ill do LTs or not.. emissions and all that crap..i need to remain street legal
As far as camshafts go... from what I have seen, cars w/ 220 cams have just as much surge at idle as 230+ duration cams. It has to do with the IAC, a few tuners I spoke with told me they were "finicky." I am looking at the TSP Magic Stick for my daily driver, I'm not afriad of a decent sized cam for a DD.
The cams w/ bad valvetrain noise are the Comp XE-R grinds from what I gather.
The gears... they will work, but I swapped my original 2.73's for 3.42's and I like how much better the car feels in around town driving vs. the stock gears. If you don't do LT's, at least do MAC midlengths.
Good luck with your future set up.
A4's came in 2.73 and 3.23.
You should be sitting nicely in the 11's with that setup. As long as you have some long tubes.
Also LT headers and y-pipe is a must with a H/C car. You will be leaving alot of HP on the table.
For stall I have a TCI and very happy with it so far. A must is also a trans cooler and I would also go with a trans-go shift kit.
I just finished doing about everything you said you where looking into doing and very pleased with my set-up.
Goodluck
