Highest horsepower - 5.7L???
Be careful of getting caught up in what people advertise. Brandon
Dyno numbers and flow numbers have ALOT in common....both are more credible at "independent" facilities that have no axe to grind and nothing to "prove".
Some of the big numbers that you have seen advertised...(and I'm NOT mentioning names) have had some pretty "clever" situations which have pumped the #'s higher....an A+ for ingenuity but a C- for credibility.
Tony M.
p.s. If I just hijacked this thread then please delete this post.
btw, here is mine:
http://community.webshots.com/photo/...96783024QdczKl
btw, here is mine:
http://community.webshots.com/photo/292511523/296783024QdczKl
the graph.......hot shot...
Ok, the.....let me rephrase that.....where is your 440 rwhp car?....or for that matter where is your 400 rwhp car?? Anyone running 13s is not EVEN CLOSE to running that kind of horsepower!!!
Rapid
Cartek
LG
Jason 99T/A
Tony M.
Brandon
Hey thanks for the compliment. Since I'm a retard, maybe I should quit my six figure job you punk ***. Probably 4 times the cash you bring home. And by the way, when did this become YOUR thread where YOU can make the rules?!?!?! If you read my original AND subsequent posts, I did NOT STATE that I was looking at a FULL OUT 346. I stated that w/o the aid of nitrous, forced induction, or a stroker motor AND runs on pump gas!!!!!!!!!!!!!!
I'll bet that you would be hard pressed to find one that puts out 500 rwhp. Go do the research in the ET database if you don't believe me!!
From some of the posts, it looks like Rapid Motorports has one, and maybe a few solid roller cams motors as well.......
And by the way: GROW UP!!!!!!
I don't think we're talking just RWHP here since all the drivetrains are different. I would assume with a 6 speed in that car it would have dynoed near what Allan cranked out.
I think full-out means all the bolt-ons, like FAST 90, EWP, Underdrive Pulley, etc etc. Btw, you can run 11.3~11.5:1 CR or so with a big cam on 93 octane.
As an example, I'm pretty sure an MS3 (237/242 113lsa) with AFR 225s milled to 58cc (so gotta wait for the 62cc version), LG Headers without Cats, FAST 90, ASP Pulley, B&B Bullets and a VaraRam will make around 515rwhp in an M6 Vette. Not only that, it'll be drivable, especially with 3.90s in the rearend. Or at least that will be my setup. Of course flycutting will have to happen, but it should be around ~11.2:1 CR, so it'll run on 93 easily with the overlap the MS3 provides.
How does that sound, Tony?
Hey, thanks for sharing your knowledge. That's exactly what I was looking for. Hopefully, we've rid this thread of the little teeny boppers that are still living with their parents.
I always appreciate professonalism
