Dissapointed w/ the dyno run
the motor is out of a 87 camaro built with 5000 miles on it l98
I dont know if you can call it l98 anymore but
here's the info and list of mods:
.30 bored to 355ci
10.25:1 compression
flat top keith black pistons
Scat 6" rods
Scat crank
Trick Flow 23 degree heads
Comp Cams XE284 cam and lifters
Summit 'Black' aluminum roller rockers
Miloden Diamond Stripper windage tray
2 1/2" headers
True 3" Duals no Cats w/mufflers
6 speed 4:10 gears
Anyways I got 278RWHP @5750 rpm (rev limiter set to 7) and 264RWTQ @5250 rpm - 3rd gear pull
It was running a little hot. they didnt take it to 7, but i dont think it'd make any difference it would only go down
Look at the chart its ridiculous getting 135 hp @ 4500 rpms.. i mean wow it dont seem that slow... i dont know if its a misread..but probably not
car is quite quicker than a stock m3 and feels quicker than a 6 spd ws6 (stock)..weights only 2800-2900 lbs
I dont know if its the dyno, but could be. They couldnt get it to read correct rpms really.. it idled at 500 and it showed 1200..
mustang dynos sux
The car is not tuned , taking it to a tuning guy (tunes vettes and v8s) next weekend.. and getting headers that all might add 40 rwhp, but otherwise why is it making low power?? its that normal for older small blocks?? Is it worth spending more money on it? Cuz I sure aint buying no new motor..
Is there anything else I can do? Comments and tips appreciated
ps blue is hp green is ft-lbs
What fuel system you runnin? Ignition, plugs, etc? Check the plugs, check the injectors-make sure they big enough and are clean/plugs gapped properly
Maybe ur runnin outta fuel if its still stock system
otherwise i dunno cuz im just a novice
Where are you located?
What are you cam specs? If this is a stock TPI set up and you have a big cam in it, there's most of your problem.
No it reallyu doenst feel.. feels like its getting plenty of power throught the entire rpm range starting with 2K
Car is carberated, electric dist., located in Wilm, NC its 1st dyno in town. Only been there for about 2 months.
I was expecting 330 rwhp which is 30 lower than what i would've gotten on dyno jet..seems about right
at least i can brag about how much i got to the motor...350? lol
