Vette + F-15 cam only. Vids :)
Cam is ground on a 236/239 .600/.611 112 +2
Still have the Stock TB and no underdrive pulley, through the Vette drivetrain.
http://kraest.com/vette/dyno.mpg
http://kraest.com/vette/idle.mpg
http://kraest.com/vette/parking.mpg
Mike
Mike
Originally Posted by Futral Motorsports
Mike,you need me to post the graph?
Mike
No prob Mike. It dosen't print the graph line correctly.
Just for you Gomer F15 12+2
You know that's the way that cam was meant to be!! Forget that 108 and lower ICL stuff. I'm going to use mine in another car I'm building and I'm going to install it on a 112icl. I wish the one I had was a 112lsa instead of a 110 though
Originally Posted by BADSZ28
Why would you want 112 over 110? Nitrous? Wouldn't the 110 give a better torque curve and under the curve power?
Originally Posted by gomer
It would peak earlier and fall off quicker on a 110. Peak torque would still be at the same RPM, you'd just have a shorter powerband with a 110 over a 112... no advantage at all in my eyes.
Hmmm..Really have to disagree on this on. For the dyno warriors this might be true,but for best ET's this isn't the best way. All depends on the PROPER use of the cam.
Here's my F15 stock headed graph that's on a 110lsa 107 or 106 icl... I can't rember which right now. Compare the power of it at a 6700rpm vs. the 110icl cam above.
Here is the graph of where we tested the cam for final specs. This is normal of setups with this cam,and they pull on out.
12-bolt\4.10 gears,LS6 intake,ported stock T\B,Pacesetter headers w\dual x-pipe.
