T-Rex cam only locked/unlocked
Old Jun 20, 2005 | 04:11 PM
BAIN's Avatar
Default T-Rex cam only locked/unlocked
Well I took the car back to the dyno to see how the gear and converter swap effected my dyno #'s. I went from 3.73's and a 4400 to 4.30's and a 4800. Here are the results.
Before with 3.73's and TCI SSF 4400 UNLOCKED.
After with 4.30's and Yank PT 4800 UNLOCKED.
After with 4.30's and Yank PT 4800 LOCKED.
I thought the hp and tq were supposed to cross at 5250 rpm????? Is there something wrong with the new graphs?
Old Jun 20, 2005 | 04:31 PM
lilbuddy1587's Avatar
sounds like the verter was messin with dyno, and the rpms are a little out of whack
Old Jun 20, 2005 | 04:32 PM
eric01ss's Avatar
what cam did u go with casue i'm about to get a trex cam
Old Jun 20, 2005 | 04:38 PM
SSick's Avatar
nothin wrong with the dyno or the converter.. theres an option in WinPEP that once selected crosses the graph properly.. tell your dyno operater to select -Force Scaling- then all your graphs will cross at their mathmatically correct 5252.
nice numbers!
Old Jun 20, 2005 | 04:44 PM
Tally TransAm's Avatar
they do cross at 5250, the scales are different
Old Jun 20, 2005 | 09:30 PM
JNorris's Avatar
Moderator
I am surprised at the difference between the locked and unlocked numbers.
John
Old Jun 21, 2005 | 07:46 AM
BAIN's Avatar
I seriously think the 4.30 gears lost the 23 hp from 380 to 356.8. I never got the chance to lock the 4400 with the 3.73 gears, but I figured it to be around 420- 425 rwhp locked.
Tally TransAm - if the scales are off then wouldn't the peak #'s be lower also? That doesn't seem right. Maybe it is hell the engine let go the same day at the track.
Old Jun 21, 2005 | 08:14 AM
777's Avatar
777
the rwhp scale and rwtq scale is different...if you look at the last graph 325rwhp is directly across from 300rwtq...
Old Jun 21, 2005 | 11:51 AM
BuckeyeROC's Avatar
King of Pigskin Knowledge
Honestly, I wouldn't be too concerned about the dyno numbers. You ran 11.0 @ 121 and hopefully will be in the 10's now with the gears and converter. That's all that matters. As long as you don't run worse at the track, it doesn't matter what it dyno's. That car is moving btw, hope I can get mine in the low 11's @ 120-ish.
