prc 2.5 with magic stick dyno
Old Jul 8, 2005 | 10:10 PM
HUNGARIAN's Avatar
Default prc 2.5 with magic stick dyno
i dyno'd my 2002 ws6 tonight 6 speed
modifications: mahle forged short block
prc 2.5 heads -milled 30ths
tsp magic stick cam shaft
ls6 intake with stock throttle body
30 lb ford svo fuel injectors
pacesetter lts
ram power grip HD clutch
stock rear end
the car dyno'd tonight 440.9 rwh with torque at 406.1
so what you think about these numbers?
dyno sheet attached
Old Jul 8, 2005 | 10:34 PM
_HAVOC_'s Avatar
pretty good, those are the same heads im looking at getting.
what kinda exhaust are you running?
looks like you could of ran it up another 200-300 rpms, and might of gained a higher peak #..... its also hard to read the a/f, kinda looks like its at 12.5 though towards the end, mgiht be a few more poneis if it were closer to 13 or low 13's. good deal though, bad *** to have a 440 rwhp all motor beast!
Old Jul 8, 2005 | 10:41 PM
VINCE's Avatar
Shorty Director
Nice!!!
Flawless02SS's Avatar
Sound very damn good to me!! Nice job!!!!!!
Old Jul 8, 2005 | 10:46 PM
383LQ4SS's Avatar
Looks like the correction is in STD...makes it a tad higher. Not much though. Excellent #s either way.
Old Jul 8, 2005 | 11:27 PM
Bo White's Avatar
Looks like ya need a ported TB , may get ya over 450
Old Jul 9, 2005 | 12:57 AM
TheHun's Avatar
Nem rossz, kiraly...
Old Jul 9, 2005 | 07:04 PM
gomer's Avatar
Good numbers, you need to lean that thing out a touch and twist it on up there to 6800 or so
Old Jul 9, 2005 | 07:59 PM
HUNGARIAN's Avatar
i'm running the pacesetter long tube headers with loud mouth exhausted without cat -
i no i no it to raspy & loud but my guys in the shop like it so much - so i'm going to leave it - so far no police ... yet !
Old Jul 9, 2005 | 09:15 PM
SideStep's Avatar
I agree...
Old Jul 10, 2005 | 11:24 AM
iamsickofitall's Avatar
how much are those heads milled and how much flycutting was required - i wouldn't think you could mill .030 and run an MS3
Old Jul 10, 2005 | 12:01 PM
jaredwayt's Avatar
that number was allright, id like to see what it did sae corrected.we did a car with the same exact setup and did like 435-440rwhp with the old tsp torquer cam .589 on a sze correction, i would think that ms3 would of went a little higher.
Old Jul 10, 2005 | 09:50 PM
HUNGARIAN's Avatar
my heads were milled 30ths & it's 5.3 liter heads-- i have mahle forged pistons with -2 cc valve relief and i used 6.125 H beam rods. i don't have a problem with valve clearance - because i already had 2,000 miles on the engine & it was still running great
i also am posting my air flow ratio print out- i will try to get the ported tb & lean it out just a little bit - then i will check the dyno again.
Attached Thumbnails prc 2.5 with magic stick dyno-lastscan78.jpg   prc 2.5 with magic stick dyno-lastscan44.jpg
Old Jul 15, 2005 | 07:24 PM
Nate_Taufer's Avatar
Forged pistons have 2cc valve reliefs probably.
Old Jul 15, 2005 | 10:03 PM
jrp's Avatar
jrp
SN95 Director
whats your CR?
Old Jul 16, 2005 | 09:22 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Great results man! Get a TB from Bo!! I guess maybe those PRC heads do work
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 9, 2005 | 06:30 PM
raymond mckinney's Avatar
Expected higher sorry!!
Old Nov 9, 2005 | 06:32 PM
2000 Tran Zam's Avatar
pacesetter lts
stock rear end
dyno sheet attached
Do you plan on spraying? i would only assume so since you said you have a forged short block...
Old Nov 9, 2005 | 11:41 PM
HartAttack's Avatar
would like to see it in SAE also. Still good numbers. No pulley either? Looks real good.
Old Nov 10, 2005 | 02:23 PM
CRL 01 SS's Avatar
Should be higher than 440 rwhp. With the PRC 2.5s only giving you a gain of about 20 rwhp over cam only cars with the MS3 and 10 bolt, they aren't very impressive. It's probably just the tune though. Take Gomer's advice, lean it out a little and twist it up to about 6,800.
