G5X4 Cam only dyno
Old Jul 24, 2005 | 12:53 PM
HumpinSS's Avatar
Default G5X4 Cam only dyno
Dyno was done through a 12 bolt with 4.33's and 27" ET streets with 16 psi
Old Jul 24, 2005 | 01:01 PM
Black02SS's Avatar
Nice numbers considering the 90*+ temps you had to deal with. She should be good for a 12.0 run.
Old Jul 24, 2005 | 02:09 PM
gator's 99TA's Avatar
its odd that the power drops off so fast after peak.
Old Jul 24, 2005 | 08:01 PM
BlueSix's Avatar
I thought that cam pulled higher than that...
Old Jul 24, 2005 | 08:07 PM
SMOKIN01TA's Avatar
Old Jul 24, 2005 | 08:34 PM
gomer's Avatar
What springs are you running??
Old Jul 24, 2005 | 09:26 PM
HumpinSS's Avatar
prc platinums. I suspect my intake hose is collapsing under loads at those rpms but forgot to look while i was dynoing the car....
I am running SD and used some hose from www.hightempsilicone.com its an 1/8" thick and my not be able to withstand the vacuum but does well with boost which doesnt apply to me....
New dynos comming soon after i get that saured away
Old Jul 24, 2005 | 10:54 PM
1QuickT-A's Avatar
yeah that cam should pull up close to 7k easy from what I've always seen..
Old Jul 25, 2005 | 12:12 AM
Black02SS's Avatar
I still don't think its the hose, but I dunno.
Old Jul 25, 2005 | 12:44 AM
Black02SS's Avatar
Read this thread I started.
https://ls1tech.com/forums/forced-induction/355607-silicone-hose-question.html
Old Jul 26, 2005 | 08:37 AM
JakeFusion's Avatar
Super Hulk Smash
What LSA is the G5X4 on?
Old Jul 26, 2005 | 10:35 AM
HumpinSS's Avatar
Here is another thread with a G5x4 graph
https://ls1tech.com/forums/showthrea...ighlight=x4%2A
Old Jul 26, 2005 | 10:36 AM
lilbuddy1587's Avatar
111 lsa for x4, and the dyno sheet i have shows the cam pulling up to 7.1k rpms..... So idk dude. Btw 921's were used as springs
Old Jul 26, 2005 | 10:43 AM
HumpinSS's Avatar
can you pm the me graph
Old Jul 26, 2005 | 10:50 AM
File is too large, whats ur email addy ? I'll send it to you.
Old Jul 26, 2005 | 10:52 AM
Brandon Boomhauer's Avatar
Was it installed straight up, or with additional advance/retard (confusing myself here on what move the powerband lower)
I would think it would peak a little higher, and keep pulling within a few hp to 7k-ish.
Old Jul 26, 2005 | 11:20 AM
HumpinSS's Avatar
Straight up like LG recommended. Sending PM now
Old Jul 26, 2005 | 11:26 AM
welll that rules out my thought...
Old Jul 27, 2005 | 06:57 AM
HumpinSS's Avatar
lilbuddy I havent gotten that email yet were you able to send it
Old Jul 27, 2005 | 10:19 AM
check ur email, sorry about the wait.
