FAST 90/90 results on Z06
Old Aug 28, 2005 | 10:36 AM
mcneil141's Avatar
Default FAST 90/90 results on Z06
Hi folks,
I finally got my 2004 Z06 on the dyno here is my old post: //www.ls1tech.com/forums/showthread.php?t=292558&highlight=mcneil141
I have added a FAST 90 intake and a LS2 TB (both ported by me), and a two tip Borla Stinger exhaust. My old numbers 430rwhp and 404rwtq corrected, yesterday I made 455rwhp and 413rwtq corrected, on the same dyno, at 12.9 flat across the board.
I guess this is one more piece of evidence that the 90/90 makes more power.
BTW, I am using the stock injectors and hit 100% duty cycle . Should I buy 36 or 42's? I think I'm done with modifying the engine .
Andy
Old Aug 28, 2005 | 11:07 AM
David Gordon's Avatar
I have the Fast 90 on my car and it didnt gain me anything. I didnt port it though. I made 475 with the stock injectors on my stroker and when I added thew Fast stuff we went with 36#.
Old Aug 28, 2005 | 11:34 AM
SideStep's Avatar
SWEET!!!
How hard was the LS2 TB to tune for idle and part throttle driving???
I am using SVO 30#s and have had no problems. I have hit a max of 74%, duty cycle at 450rwhp(sae). You will be fine with them!
...congrats
Old Aug 28, 2005 | 12:58 PM
mcneil141's Avatar
Hi,
The LS2 started right up with no problems. I have the smallest bit of surge at 1800, but I will solve it eventually (some of that may be left from incomplete tuning from the cam). I read that the LS2 gives up a few ponies over the NW unit, but the drivability is great. Most would never know I changed something.
When you get the FAST, you will see what needs work ..sharp edges, flash lines, and some protrusions. I also completely port matched the lower half, placing the unit on the heads, then removing, grinding and sanding to match. I finished up by wet sanding everything I could reach. I spent quite a bit of time on it, but that's how I relax.
BTW, my FAST was NOT warped and I have no complaints. Be sure to order new manifold gaskets.
The FAST is well worth the money. I bet you make at least 20rwhp. My first pull with no tuning was 447rwhp which is 17rwhp over where I started (remember that I added Borlas, too).
Thanks for the info, I will order the SVO's tomorrow.
If you have any questions, let me know.
Andy
PM sent to Sidestep
Old Aug 28, 2005 | 01:27 PM
Patrick G's Avatar
LS1 Tech Administrator
Congrats. Those are some solid gains with the FAST 90/90.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 28, 2005 | 05:35 PM
SS1875's Avatar
Very nice. If your sure that the modifying is over the SVO 30# injectors should be fine however, if there is any doubt in your mind go with the SVO 42# injectors that way you will have one less thing to think about down the road.
Old Aug 28, 2005 | 05:48 PM
pdd's Avatar
pdd
congrats
Old Aug 30, 2005 | 11:39 AM
jfm's Avatar
jfm
Great gains you made.I picked up a total of 10 rwhp with my FAST90 and NW90 TB over my LS6 intake with ported TB.I wonder how much the exhaust change was worth?
I run SVO 30 pound injectors.
Old Aug 30, 2005 | 12:35 PM
JoeyAnderson's Avatar
SWEET gains! And you're local, too.
PM Sent!
Old Aug 30, 2005 | 07:28 PM
mcneil141's Avatar
Thanks for the compliments, folks.
(From what I hear) the exhaust change is mostly for sound, maybe a few rwhp. The stock Ti system flows pretty well. Sounds good though....
I studied my duty cycle from my dyno pulls.. I am *just* under 100% duty. I think the SVO 30's will be perfect.
Keep in mind that my gains were over an LS6 intake and stock TB.
Old Aug 30, 2005 | 08:39 PM
Airwolf's Avatar
Nice gains. Figure 5rwhp for the exhaust if lucky, so a soild 12 is not bad. I personally believe that the more these engines are modified (heads/cam/headers/exhaust/TB/intake) the more rwhp the FAST gets.
Thanks for the info and congrats on the new numbers!
Old Aug 31, 2005 | 09:16 PM
mcneil141's Avatar
Actually, I went from 430 to 455, so the gain is more like 20rwhp! I paid more $ for less hp with my headers.
Andy
Old Sep 1, 2005 | 01:40 AM
DONAIMIAN's Avatar
Im getting curious to if I would see a gain with my 221/221 cam.
Old Sep 17, 2005 | 10:27 PM
builts10's Avatar
thats nice. ls1 all the way
Old Sep 18, 2005 | 03:01 AM
RedHardSupra's Avatar
if you're at 100% now, then svo30s will bring you down to maybe 85-90. get the svo42s and run with a healthy margin, the differnce is like 50bux anyway.
other than that, NICE numbers!
Old Sep 18, 2005 | 01:30 PM
marine02ss's Avatar
I also just installed the 90/90nw on my 02ss havent tuned or been to the dyno.but my buddys 02CETA makes 415rwhp we raced and were side by side all through the gears his is a manual mines a automatic Any guess how much power im making,ls6 cam,hk long tubes,lid,tci 3500
