Another disappointed result, TR 224
Old Nov 15, 2005 | 04:31 PM
  #41
'Trust''s Avatar
It doesnt sound noisy, and i remember lining the dots up, and turning the motor over and making sure they were lined up (i know theres no way it'd change but i wanted to make sure) so those are, my plugs arent gapped i dont think i did them like 30k ago, could that do it? I double checked my rockers and they are torqued to spec, and i have to buy a hose to attach to this gauge to do the compression check to see where that is
Old Nov 15, 2005 | 11:17 PM
  #42
Mike K.'s Avatar
even if a rocker is tq'd to spec the preload could be off and thats what will kill you, your goal is if I remember right to hit 3/4 to 1 turn after 0 lash for the proper preload, somebody correct me if I am wrong.
Old Nov 16, 2005 | 12:55 AM
  #43
BrianC98Z28's Avatar
For LS1s all you do is torque to spec and go. LT1's are a different story. For every cam install Ive been a part of(4) we've just torqued it to spec and done. Never any problems. Line up dot to dot,torque and done. Is this going through a stock converter or bigger? Heres what I'd do if I was you. Take it apart and make sure again everything is lined up dot to dot then get an LS6 Intake,Pulley, redyno and see what happens.
Old Nov 16, 2005 | 02:50 AM
  #44
ExceSSive's Avatar
You are correct sir...you torque (22ft/lbs I believe) and go. They are self adjusting rockers with no backlash to adjust.
I too have the 224 cam with heads and put down 390, and that was fine with me. I am going to do the free mods, exhaust and see if I can't reach the magic 400.
Jon
Old Nov 16, 2005 | 03:59 PM
  #45
'Trust''s Avatar
Its through the stock converter, i dont have heads, stock 98 ones, which im told flow worse than the rest
Old Nov 16, 2005 | 05:46 PM
  #46
KNOURROL's Avatar
You just mean that your cam and crank dots werent lined up?
Heres the graph.
Yes, they were not lined up. Looking at your graph, aren't your hp and tq curves crossing a little early? Or am I reading it wrong? It looks like they cross somewhere around 4800 rpms. (Or do I need new glasses?)
Old Nov 16, 2005 | 06:02 PM
  #47
ws6sojuiced01's Avatar
man i maid that power with close to the same mods and no cam must be the intake.(on a dyno jet)
Old Nov 16, 2005 | 06:08 PM
  #48
'Trust''s Avatar
Nope, your glasses are good, so what does this mean?
Old Nov 16, 2005 | 06:21 PM
  #49
'Trust''s Avatar
Could i not pull the valve cover and make sure #1 is TDC for compression stroke and see if both valves are up to see if the timing is off on the cam or do i need to pull that front cover off?
Old Nov 16, 2005 | 08:45 PM
  #50
Mazzenger's Avatar
Did you jabber at those cats at extreme to see what
their thoughts were about it?
Maybe you baseline dyno was with a locked converter and this one was unlocked??
Old Nov 16, 2005 | 08:51 PM
  #51
SideStep's Avatar
Look at both sides of the dyno sheet... they are not to the same scale. This happens alot, no big deal still SAE correction.
Old Nov 16, 2005 | 10:28 PM
  #52
'Trust''s Avatar
Yea i talked to Robert and Jason about it, Robert said that they are low for the car, and that the intake and heads are probably holding me back, and i'll get maybe 25 w/intake and pulley, but they arent horribly low either so its kinda weird. I dont think the numbers are off due to the verter, i raced my buddy's SS on the way home from picking his car up from his tune, it did 330/352 and i put a fender on him, so i say they are on. (lid and cutout)
I finished the compression test up just now and here are the numbers: 1=190psi, 2=195psi, 3=190psi, 4=182psi, 5=190psi, 6=200psi, 7=185psi, 8=190psi. They seem good to me, the dots on the crank and cam are lined up aswell, so i dunno, any more thoughts?
Old Nov 17, 2005 | 09:20 PM
  #53
Mazzenger's Avatar
Are you on the stock converter?
My 221/221 would cam would bog horribly with the stock converter.
Old Nov 17, 2005 | 11:43 PM
  #54
Mike K.'s Avatar
Yes but he has different pushrods and cam right so the geometry is not stock anymore.? Can't hurt to check cause something is not right.
Old Nov 17, 2005 | 11:59 PM
  #55
Stock length pushrods and small cam, and it doesnt matter like I said on LS1's you just torque and your done but on LT1s you have to check all that stuff, Im telling you thats the way it is. Also Ive never heard the 98 heads flow less than others, hell my buddy ran 10.92 with cam/nitrous with stock 98 heads. I ran 12.0 boltons with stock 98 heads so I doubt that. Get a pulley & Ls6 intake and redyno if you want.
Old Nov 18, 2005 | 09:36 AM
  #56
'Trust''s Avatar
I'm using stock length pushrods, is there ANYTHING else i need to check? Im stumped after this compression check
Old Nov 19, 2005 | 06:43 PM
  #57
kilr12's Avatar
Hey 98nbm,did you find the prob,check my dyno post after dropping 4K on my car i gained 46 rwhp for 4K.I also need help!!!
my post is (anther bad dyno story)
Old Nov 19, 2005 | 07:25 PM
  #58
'Trust''s Avatar
Not yet, im still working on it, were you patriot ls6's part of the 4k?
Old Nov 19, 2005 | 07:28 PM
  #59
kilr12's Avatar
yeah,that's for everything.I cost me 4k to get 46 rwhp! not right.
Old Nov 19, 2005 | 08:44 PM
  #60
1SlowHoe's Avatar
Destroyer of Transmissions
I'm not real smart on tuning, especially a N/A car. I thought N/A was supposed to be closer to 14:1 AFR? 13:1 seems really rich and giving up some power. Isn't stock something like 14.7:1? Maybe I'm way off
