TEA 5.3 Stage 1.5/G5X3 Combo
Anyone running this combo?
I'm wanting to see some dyno#'s. I've searched and haven't found any threads. Any educated guesses on what I might get? I'd also be spraying 150 on top of this too.
Supporting mods:
Shaner Ported Throttle Body
LS6 Intake
G5X3
ASP Underdrive Pulley
Pacesetter Headers
Custom 3Inch True Duals (XPipe)
T56
12bolt 4.10 gears
Supporting mods:
LS6 Intake
G5X3
Pacesetter Headers
T56
12bolt 4.10 gears
We have not used an X3 with those heads, but we have used the smaller G5x1. JNorris here picked up ~ 2-3 tenths with a custom cam we ground specifically for those heads, over the X1.
I think that the X3 will make more power, simply because it has more duration, but if you would like something a little bit smaller on a single pattern, let me know and we can go from there.
Louis
Louis
i did 440rwhp and 408 rwtq with a g5x2 and some very old TEA stage 2 5.3s. this was through a 12 bolt, 4:30s, 3.5 drive shaft, and 18x10 enkis wrapped in 315s (heavy as ****). it ran 11.7s full wieght at 4200' above sea level. it had all the normal bolt ons avialable at that time (no electric water pump or fast intake). it was a bad *** set up.
Originally Posted by project98LS1
you should of checked out the sticky on the top of the page.
Supporting mods:
LS6 Intake
G5X3
Pacesetter Headers
T56
12bolt 4.10 gears
Supporting mods:
LS6 Intake
G5X3
Pacesetter Headers
T56
12bolt 4.10 gears
Originally Posted by mellowyellow
Hey Jay whats up ? What did you put down sat at the Dyno day ? I was talking to Lydia about a cam swap I'm doing and did'nt see ...
last time i dynoed that day we met it did 555/562 on the squeeze. Keith thought it would have gone over 560 with a full pull.
I had thought about getting that cam when i put my combo together but i didnt want to flycut my pistons. I have a buddie of mine w/ the x3 and PP heads that only put down 420 so i was happy w/ my results but i still fell a little short of my goals. i wanted 450 rwhp.
