Highest NA dyno???
Old Jan 30, 2006 | 05:47 PM
Onyx LS1's Avatar
Question Highest NA dyno???
Just curious what the highest Dynojet numbers are these days.
What are the highest LS1/LS6 NA?? What CID and cam?
Graphs would be awesome.
-JJ
Old Jan 31, 2006 | 01:33 AM
LTLHOMER's Avatar
I know of a 725+ fwhp n/a ls1...don't know if they ever put it on the rollers or not but that was the engine dyno numbers...real streetable car too.
Old Jan 31, 2006 | 12:51 PM
DAPSUPRSLO's Avatar
750ish rwhp by SAM on a 427 inch ls6 headed all out (still wet sump, still ls6 heads though) race motor on race gas. Was through an efficient jericho manual transmission.
Old Jan 31, 2006 | 04:24 PM
matt346ls1's Avatar
They better check there dyno for accuracy. The #'s they ran at the weight they were at would say they were not that high. Not bashing anyone just telling the truth.
Matt
Old Jan 31, 2006 | 04:37 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
My old 402 nitrous motor with marginal quality C5R heads and a less than spectacular custom intake made 751 flywheel.ARE did the heads and most of the intake.
Old Jan 31, 2006 | 05:15 PM
LTLHOMER's Avatar
Matt
Yeah I gotta agree with you Matt...
Old Feb 1, 2006 | 07:02 AM
DAPSUPRSLO's Avatar
Matt
Quite possibly, but this is just a sample of some numbers I entered in the calculator Richmond Gears has and it's pretty much right there. RPM doesn't really effect this calculators prediction of et's, only gear selection. I have no idea to the accuracy of this calculator though, nor do I know 100% that that is the actual raceweight of the car, but I know it was over 3000 by a good bit.
Vehicle Weight (in pounds): 3300
Vehicle Horsepower: 850
RPM through lights (finish line): 8800 (guess)
Tire Diameter (Hght.) in Inches: 29.5
1/4 Mile ET: 9.08
1/4 Mile Top End Speed: 148.95
Ideal 1/4 Mile Gear Ratio: 5.19
1/8 Mile ET: 5.78
P.S. Dropping the weight to 3200 makes a difference of two mph and less then 1 tenth, just checked it.
http://www.richmondgear.com/112901.html
Old Feb 1, 2006 | 10:27 AM
matt346ls1's Avatar
1/4 Mile ET: 9.08
1/8 Mile ET: 5.78
A 5.19 gear is a bit steep and I went 9.27 @ 148 with a 4.56 gear at 8000 rpm's with 570 rwhp. Cool little deal though.
Matt
Old Feb 1, 2006 | 10:43 AM
Ben R's Avatar
Matt
The dyno is correct. The ET wasn't as low as the MPH showed it should be due to the clutch setup. It was their first time out with all of the new power and the clutch setup was a little off.
Old Feb 1, 2006 | 12:17 PM
matt346ls1's Avatar
When it ran 154 or the next week when it only went 146?
Old Feb 1, 2006 | 12:27 PM
DAPSUPRSLO's Avatar
Matt
Matt, how much does your car weight?
Old Feb 1, 2006 | 04:58 PM
matt346ls1's Avatar
3300 raceweight at the time
Old Feb 1, 2006 | 05:26 PM
TOSTO RACING's Avatar
I made 585 rwhp which is close if not right at 700 flywheel.
Weighs 3451 and went 139.88 so far with a 6-spd.
Old Feb 2, 2006 | 12:21 PM
Ben R's Avatar
If you're trying to say that the school has lied about something, you should just come out and say it. I don't like dancing. Nobody can dispute the car ran 154 MPH. There were a handfull of people out there to witness it, me being one of them.
Old Feb 2, 2006 | 03:58 PM
matt346ls1's Avatar
I'm not saying they lied but I would hope if he had 180rwhp more than my car then it would go more than 1 tenth faster than I did. Especially in good air and good elevation. Who knows maybe my dyno is wrong.
Matt
Old Feb 2, 2006 | 09:52 PM
Ben R's Avatar
Given more time with the clutch the car made enough HP to run 8.70's. The 9.19 was the cars first or second pass with the new engine.
Old Feb 4, 2006 | 10:10 AM
raymond mckinney's Avatar
The cars fast and that's all that counts. Who cares what it dyno's it runs low 9's.
Which last time I checked was fast on the motor?
