222-222 Cam Results
398 rwhp - 381 rwtq
My combo:
205 AFR Heads (out of box), 222-222 .581 - .581 115.5 LSA XE-R Cam, 2800 Vig Converter, Kooks 1 3/4" inch Headers (coated), 3" catted coated y-pipe (fabbed by Speed Inc), Whisper Lid, GMMG Catback.
So what do you all think? Good, bad, somewhere in between?
Car has good driveability and like the sound now with the headers
Just a Felpro LS1 headgasket (compression should be stock)
As far as cam installed with advance, I don't think so, but I would have to check with our sponser, Speed Inc, who has done all of the work/tuning on this car.
Do have an under-drive pulley??? If not... AND you were looking for a little more, Get the pulley and ported TB and see 12-14 rwhp... Still want more? Mill your heads .018 to 63cc chambers and use a .045 Cometic gasket. This will raise you DCR to 8.53 and your static to 11.05, worth another 8-10 rwhp. I am assuming your cam is +2 advance and your pistons are .007 out of the hole...
Maybe 25rwhp more for all the above, on a good tune...
