Holy Sh*t,prc Stage 1 Dyno Results!!!
Old 04-08-2006, 06:58 PM
  #61
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Steve, you can use either MLS or the graphite with the LS6 heads. Just be sure to remove all of the old graphite gasket and wipe the deck with carb cleaner on a rag before reassembly.
One more tip, with removing graphite gaskets, scrap off all the big pieces leftover first. Then use "Gasket Remover" spray from an auto parts store, it saves a little time as the gasket will then pretty much peel away.
Old 04-08-2006, 07:04 PM
  #62
steveb's Avatar
Sounds good thanks Joe, now i need to locate a set of head bolts tonite. If not i'm not shure when i will get another chance to borrow the lift.
Steve
Old 04-11-2006, 06:11 PM
  #63
1MEANGTO's Avatar
I have my heads on getting tuned thursday morning. Oh we'll be spraying the 150 at it too.
Old 04-11-2006, 08:27 PM
  #64
cantdrv65's Avatar
Thumbs up
Cool. Cant wait to see your numbers!
Old 04-11-2006, 10:04 PM
  #65
1slowls1's Avatar
I just ordered the TSP Camshaft, 918 Springs & Pushrod Package with the 228r cam 228/228 .588/.588. Could I throw on a set of the PRC LS6 CNC Ported Heads with the comp cnc valve job with out any problems? What kind of power wouold i be pulling after that possibly.
Old 04-11-2006, 10:50 PM
  #66
steveb's Avatar
If the MS3 fits without any problems you should be fine. As far as power i could guess but i'll leave that up to the experts.
STEVE
Old 04-12-2006, 12:05 AM
  #67
matts22's Avatar
Originally Posted by Trevor @ Texas Speed & Perf.
Yes, the heads are available with the PRC dual spring kit. The heads are $899.99, the competition valve job adds $100, and the PRC dual valve spring kit adds another $259.
As for a large-chamber head, we could setup a set of 6.0L heads using the same ports. Only difference is you'd have a 72cc chamber instead of the LS6's 64cc. The price would be the same as the LS6 for a set of 6.0L heads setup respectively.
Let us know if y'all have any other questions!
Trevor
Texas Speed & Performance
Have you tested heads with and without the competition valve job to see how it affects the curve? I'm interested to see this. What size valves are used in both setups? How much flow increase have you seen? Thanks!
Old 04-13-2006, 03:31 PM
  #68
1MEANGTO's Avatar
Well my injectors showed up and they are ev6 ones not ev1's so now i need different ones.
Old 04-13-2006, 05:07 PM
  #69
steveb's Avatar
Shooting for a saturday install so numbers should be up next week.
STEVE
Old 06-30-2007, 04:41 AM
  #70
Websy21's Avatar
After all of this now I'm not sure what heads to go with. I had my mind made up with the tsp 2.5's, and jsut deciding on a cam. Was thinking something like the 232/228. Guess I have to start all over again. Impressive gains though! I am going to have to talk to TSP and see whats up????
Quick Reply: Holy Sh*t,prc Stage 1 Dyno Results!!!
