LS2 402 Way Low Dyno Numbers. Help Please!
https://ls1tech.com/forums/pcm-diagnostics-tuning/498799-i-can-t-seem-lean-her-out.html
As usual, several people in the know stepped up and gave me some pointers which allowed me to get it worked out. My AFR is right at about 12.8:1 or so. I am now ready to strap up and put down some aggressive numbers. I hope to get that done very shortly but I feel very confident about it.
I have thrown a couple of codes with regards to voltage or something.
Could I take the TB off my 04 GTO and just swap it using the sensor in the newer one? Is it compatible mechanically (I know that it is) and electronically ?
Our issue was a fuse for the injectors.
Car pulled 475 through a built A4 w/ stall.
