any 6.0 A4 ms3 cam numbers?
sweet truck! should be a dirty devil once your done! if i were to guess i would say 360-370 you'll lose a bit with A4 tranny, gears and rear end itself. are the heads ported? and are they the 6.0l LS6 style head? compression is a little lower on the truck motors arent they? plus the heads will lower compression a bit too.
My car should be on the road with in a couple of weeks and have nearly the same setup as you, I'll let you know what I get if I hit the dyno before you.
LQ9
LS6 Intake
PRC Stage 1 heads
MS3.
700r4
LQ9
LS6 Intake
PRC Stage 1 heads
MS3.
700r4
well i have a regular ole LS1 block with an S cam(pretty much the same thing), i made 382 through the 4l60 with a converter, im guessing you might be right around there give or take a few ponies, but its all about the track time
