Weekend Dyno >650 RWHP TTi Street Turbo
Well I hit my goal over the weekend. My last dyno I hit 643rwhp/621 rwtq and I was pretty happy with that since the kit was never really designed for these hp levels. After chasing down some gremlins over the course of the year, I hit the rollers this weekend.
VIDEO LINK HERE
With the the WG spring at 10.5 psi and the manual boost controller turned all the way up I did theree pulls dialing in the AFR and timing.
Anyway the Results were:
1st 659.5hp/625 Tq (Actual) 642.4/608.8tq (SAE) This run was odd, cause it didn't start logging till very late in the pull.
2nd 671.4hp/758.1tq (Actual) 653.6hp/738.2tq (SAE) Good Clean pull
3rd 665.5hp/802.6tq (Actual) 648.2hp/781.7tq (SAE) Brake Boosting for the Tq!
The Combination:
TTi Street kit T-76 (on center, .96 turbine ar) Custom FMIC
Futral 370 9:1cr short block
AFR 225 72cc heads w/upgraded AFR springs
Comp Cams 224/224 Cam .576 lift 116 lsa (custom, idles at 650-700 rpm)
Ported LS6 intake (LS2PortWorks) Port matched to the Heads
Stock Throttle Body
60lb Motortron Injectors
Dual intank 255's
Snow Methanol injection (100% Methanol)
Fuel controlled by Accel
Ignition by HP Tuners
SDPC Ported Oil Pump
Transmission is a Speed Secrets 4L65-e
Converter is a PYE 3400
Moser/HighSpeedProducts 9" w/3.50 gears and a LSD
Wheels were 17X11's with Hoosier 335/35/17 Drag Radials (Thanks again Mark)
The AFR ended up a bit rich at TQ peak 10.1:1 then ending up right at 11.5-12.0 at HP Peak. Timing was set at about 16.5 at Peak TQ and 20.5 at Peak HP.
Going over my log files I have officially come to the limit of the TTi Street kit. I had my Boost controller pretty close to max. I was making 18.7 psi at 4800 rpm that would gradually drop to 15.5 psi at 6300. I am pretty sure thats all she's got. The fuel system seems to be working pretty well, as the Turbo is maxed out and the injectors are about 94% duty cycle. It would be really interesting to see what the exhaust manifold pressure is, I am guessing around 45-50 psi (no exhaust scavenging here!).
Keep in mind, if this were a manual car, it would have been well over 700RWHP.
Special Thanks go out to:
Turbo Technologies for a great kit!
LS2PortWorks for a great hookup on the manifold
Scoggin Dickey Parts Center for all the odds and ends (Best, Hands Down!)
Here is one Dyno Graph I only pulled it up to 5900 rpm on this pull (the Blue line is WAHUSKER's D1SC 402). Yes its Actual, but the SAE numbers are above.
![](https://ls1tech.com/forums/attachments/northwest-members/75318-ryan-1-mark-2-blower-vs-turbo-dyno-sm.jpg)
Ryan K.
VIDEO LINK HERE
The Combination:
Stock Throttle Body
Dual intank 255's
Ryan K.
LS1 Tech Administrator
Dang son, that's some stump pulling power and torque. Any ET's with the latest power settings?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
ever consider a bigger cam? that 76 has a lot more in it, and imo I'd gladly trade 100 ft/lbs for a 100 rwhp on your setup, especially a stalled automatic....
I really like my little cam, LOL, I like keeping the RPM's down where I am not killing the rotating assy/valve train. As for the turbo, it really is done, you have to remember that this is an on-center housing. If it were a Tang it would have more in it. On-Center=too much back pressure.
That was a very impressive dyno session Ryan! Your car is still the one to beat in these parts.
I didn't think I had found enough hp to beat you, but I thouhgt I had you covered in the tq category. Oh well.
Should be a lot of fun this weekend at the track between you & me & Ellis all going for new bests.....
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Originally Posted by Ryan K
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![](http://www.rkarasek.com/images/WOOT.jpg)
Ryan Happy...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Good luck Ryan .
peace
