TSP T-200cc numbers?
More interested in "baby" cam graphs like a Torquer 2 with a 112 LSA.
Want to know how it compares to Dart 205's with a similar sized cam and LSA.
Intake: LS6..MAF De-screened.
No pulley..No ported TB.
Thru Hi-Flow cats.
Since the Torque reading had some problems, perhaps this will help.
Using www.f-body.org/gears, and verifying with my own car..here are the rpm's for various engine speeds based on a 3.42 final gear ratio.
2000rpm = 45mph
3000rpm = 67mph
4000rpm = 89mph
5000rpm = 112mph
6000rpm = 134mph
6600rpm = 147mph
I just used the formula TQ=HP x 5252/rpm
You know HP, and just put in those rpm's and you can see 400ft/lbs of Torque is hit really low...Hope that helps..I'm quite pleased..
I meant to say that 400ft/lbs of TQ was hit very early in the curve.
For instance at 67mph (3000rpm) it looks like the HP is 230.
TQ=HP x 5252/rpm..I calculate 411ft/lb TQ at 3000rpm. Using that formula
it held 410-420ft/lbs TQ from 3000-5000rpm's. At 5252rpm (117mph) HP & TQ are always equal, so it still had 405ft/lbs TQ at 5252rpm. Dopped to 400ft/lbs TQ at about 5500rpm. At 6300rpm TQ was still at 350ft/lbs.
Maybe somebody has an Excell program that can display this easier. Just a problem with the voltage/rpm readings on the dyno that didn't allow the above calculations to be plotted on the dyno chart.
Bottom line..Torque was over 400ft/lbs from 3000-5500rpm's. And believe me that kind of torque gain was a very noticable gain..
I believe the dyno reading that day was using a STD reading (1.11..)
I used several different conversions and the SEA and STD readings that day were for all pratical purposes virtually identical.
..Temp 66.19F 26.86in-Hg Humidity 31%. Elevation ~3290'.
I know most users want SAE..Just in the spirit of full disclosure..
In any case, the torque and throttle response is for real, and it starts as early as 2500rpm..
The original dyno graph did not have the actual plotted torque curve due to circumstances beyond my control. The dyno was unable to directly pick up the rpm due to unusual voltage/induction problems on that paticular dyno on that day. Nothing to do with the car. Nothing to do with the shop.
Horspower curve was 100% accurate.
The computed HP was based directly on engine speed, a totally acceptable method and is just as accurate as having being plotted directly vs rpm.
I then converted engine speed into rpm. Computed the TQ based on the engine speed/rpm. Since I did not have the program directly sent to me as a file in the Winpep 7 dyno program, the figures were taken directly from the dyno graph.
Re-calculated the dyno run from a STD reading to SAE. It was off by about 1%(lower) from the previous HP/TQ posting. The corrected data was then put into an Excell program and re-calcuated.
I made an earlier TQ/@3000rpm posting that was not correct. I apologize for that. I should have triple-checked my figures before posting.
Having said that I can quote the following data with absolute certainty.
PRC Terminator Heads/comp Cam 228/232 110+2
LS6 Intake. No pulley..No Ported TB..
3000 rpm/ 220HP 386TQ
3500 rpm/ 264HP 397TQ
4000 rpm/ 306HP 402TQ
5000 rpm/ 392HP 412TQ
6000 rpm/ 423HP 370TQ
6250 rpm/ 418HP 351TQ
Peak Hp 422.55 @5800 rpm Held 422-418 Through 6250rpm..
Peak TQ 411.75 @4800 rpm
Once I figure out how to send and post an Excell graph on LS1Tech, I would be more than willing to post it.
To specifically answer your question. I still have 3.42 gears, so on breaking the tires loose.. I have never been able down much more than a 10-25 foot laydown of rubber, and I'm running out of money to burn this brand of tire down too more. At 5240' altitude, the "uncorrected power" is ~16% lower than at sea level. So my comments of power would be much realistic if said took a jaunt down to Houston, TX., closer to sea level. I have done a few 4k clutch drops and maybe my tires are just unusually sticky, because what usually happens is just that I go in a straight line with a minimal amount of tire spin.
I can tell you that below 1500rpm, I have not noticed any appreciable TQ gain from my previous set-up. I can start feeling it at 2000rpm, and at 2500rpm it has a strong and almost instantaneous throttle response, and the feels like the TQ curve is in full upward ascent.
Even assuming (since the dynp graph didn't start til 3000rpm) that the car has "only" 165HP at 2500rpm, that would be ~350ft/lbs TQ. Even at this altitude it does breaks the tires loose, a 1-2 shift requires good traction, and in mine opinion it is that part throttle response and TQ response that I never seemed to have with a "bigger" cam/larger runner heads.
Of course I did have this cam installed on a 108ICL because I prefer 2500-6250rpm driving range.
It worked for me. Again, I apologize that my original TQ posting was not acceptably accurate, but you still must admit it are some pretty good numbers for this set-up and fairly limited bolt-ons.
Yes, its a long post, but I needed to set the record straight. Great TQ down low. Figures needed to be corrected. There are now.
Hope this answers your question, and clears up any confusion. Thanks for understanding..Shawn..
